Cisco Router Multicast Assist...
Jul 7th, 2009
Hi all,
Here is the topology:
R9 <----> R8 <----> R7
When I attempt to ping from R7 to 239.0.0.1, I get no responces.
The configurations are below, am I missing something in the configuration?
R9:
interface Loopback0
ip address 3.1.1.1 255.255.255.0
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip igmp join-group 239.0.0.1
duplex auto
speed auto
router rip
version 2
network 1.1.0.0
network 3.1.0.0
no auto-summary
R8:
ip multicast-routing
ip address 2.2.2.12 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
interface FastEthernet1/0
ip address 1.1.1.12 255.255.255.0
ip igmp limit 100
duplex auto
speed auto
router rip
version 2
network 2.2.0.0
network 1.1.0.0
no auto-summary
ip pim rp-address 4.1.1.2
R7:
interface Loopback0
ip address 4.1.1.2 255.255.255.0
ip pim sparse-mode
ip address 2.2.2.2 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
router rip
version 2
network 4.1.0.0
network 2.2.0.0
no auto-summary
Overall Rating: 5 (2 ratings)
Edison Ortiz Tue, 07/07/2009 - 11:18
  • Hall of Fame,
    Founding Member
You need to enable Mcast routing and PIM under the interface on R9 in addition to having the 'ip pim rp-address' info for it to respond to the ping.
You also need PIM enabled on R8's F1/0 interface.
HTH,
__
Edison.
Harold Ritter Tue, 07/07/2009 - 11:41
  • Cisco Employee,
Edison,
You only need the "ip igmp join-group" command if you want R9 to act as a host.
Edison Ortiz Tue, 07/07/2009 - 12:06
  • Hall of Fame,
    Founding Member
Harold,
It's one of the oddities when doing Host Mcast on Cisco routers. It won't respond to pings.
I dumped his config on a lab and the mroute table looks at it should, yet the host does not respond to pings:
RP Mroute Table:
(*, 239.0.0.1), 00:00:24/stopped, RP 4.1.1.2, flags: SJCF
Incoming interface: FastEthernet0/0, RPF nbr 2.2.2.2
Outgoing interface list:
FastEthernet0/1, Forward/Sparse, 00:00:24/00:02:35
(2.2.2.2, 239.0.0.1), 00:00:24/00:02:59, flags: FT
Incoming interface: FastEthernet0/0, RPF nbr 0.0.0.0
(4.1.1.2, 239.0.0.1), 00:00:22/00:02:59, flags: JT
FastEthernet0/1, Forward/Sparse, 00:00:22/00:02:37
The source sending packets:
R7#ping 239.0.0.1 repeat 10
Sending 10, 100-byte ICMP Echos to 239.0.0.1, timeout is 2 seconds:
If you go to the host, it doesn't know the RP:
(*, 239.0.0.1), 00:01:20/00:02:21, RP 0.0.0.0, flags: SJPL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
(*, 224.0.1.40), 00:01:20/00:02:23, RP 0.0.0.0, flags: DPL
Now, If I enabled Mcast routing along with PIM on the interface *and* the rp-address static info:
Reply to request 0 from 1.1.1.1, 120 ms
Reply to request 1 from 1.1.1.1, 120 ms
Reply to request 1 from 1.1.1.1, 180 ms
Reply to request 2 from 1.1.1.1, 120 ms
Reply to request 3 from 1.1.1.1, 92 ms
Reply to request 3 from 1.1.1.1, 152 ms
Reply to request 4 from 1.1.1.1, 120 ms
Reply to request 5 from 1.1.1.1, 120 ms
Reply to request 5 from 1.1.1.1, 232 ms
Now, see the difference on the host Mcast routing table:
R9#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.0.0.1), 00:05:08/stopped, RP 4.1.1.2, flags: SJPL
Incoming interface: FastEthernet0/0, RPF nbr 1.1.1.12
(2.2.2.2, 239.0.0.1), 00:03:30/00:02:41, flags: PLT
(4.1.1.2, 239.0.0.1), 00:03:30/00:02:41, flags: PLT
Harold Ritter Wed, 07/08/2009 - 10:33
  • Cisco Employee,
Edison,
I guess running a router as a host is not officially supported and the behavior might differ from one level of code to another. I tried with the latest 124 and it work just fine without enabling "ip multicast-routing" and yet the latest 12.4T requires it.
Edison Ortiz Wed, 07/08/2009 - 10:38
  • Hall of Fame,
    Founding Member
Harold,
FWIW, I was running 12.2S
Harold Ritter Wed, 07/08/2009 - 10:45
  • Cisco Employee,
Edison,
I guess the bottom line is that having "ip multicast-routing" will always work, whereas not having it will sometimes not work. So it is probably better configuring it when the router is used to simulate a host.
Edison Ortiz Wed, 07/08/2009 - 11:22
  • Hall of Fame,
    Founding Member
Yup, that's why I said one of those oddities with Mcast host and believe me I've discussed this with Reed on several occasions :)
Harold Ritter Wed, 07/08/2009 - 11:36
  • Cisco Employee,
Thanks Edison. Reed is definitely the man when it comes to multicast ;-)
lrm001c474 Tue, 07/07/2009 - 11:42
Multicast-routing needs to be enabled even if R9 just wants to join the group?
Thanks.
Harold Ritter Tue, 07/07/2009 - 11:50
  • Cisco Employee,
No. "ip igmp join-group" should be just fine.
Edison Ortiz Tue, 07/07/2009 - 12:36
  • Hall of Fame,
    Founding Member
Unfortunately, when having a router acting as a Mcast host - that's the case.
__
Edison.
Harold Ritter Tue, 07/07/2009 - 11:31
  • Cisco Employee,
Robert,
PIM needs to be enable on R8 interface facing R9 (F1/0).
Mohamed Sobair Tue, 07/07/2009 - 12:13
  • Gold, 750 points or more
Hi Harold, Edison, ALL,
My point is that IGMP has to be enabled as well as Pim inorder for the information gets to all routers part of that group.
You either enable pim or create stub multicast routing.
Sorry its not my day, the USA and the whole world has lost a legend THE King Of POP (Michael Jackson). God Mercy On his Soul.
Mohamed
