Unity Physical Memory Usage is 99.38%,
which exceeds the threshold of 98%
What should I do to fix this? Do I need to shrinkdatabase?
Pls let me know
TIA
Kads
Jaime Valencia
Look at the task manager to see what's eating up the CPU, i'd recommend you to open a TAC case, there is a keyword for high CPU/memory
java
if this helps, please rate
java
