Jaime Valencia Tue, 07/07/2009 - 11:48
  • Cisco Employee,
  • Hall of Fame,
    2011
Use CAR for that purpose, refer to the documentation to understand the capabilities of CAR reports. You won't see rejected calls.
There are plenty of posts for CAR setup if you need help, just use the Search NetPro option.
java
if this helps, please rate
