RME 4.2: how to schedule the purge of the history of PurgeJobs ?
Jul 7th, 2009
beside the fact that the job and report history in RME can fill-up a lot of space in RME db, it has an impact on some other points as well (e.g. long loading of RME Home page). So it is a good thing to configure job and report purging in
RME > Admin > System Preferences > Job Purge
When this feature is enabled for every listed item on that page to let it run periodically, the jobs will be handeled very differently.
They all run at the scheduled time - there is no difference - but some of them keep a history of their run, i.e. they are scheduled as an instance of the original job - which I think reverts the original idea behind...
Or did I miss something and someone tell me where I can configure the schedule to purge the history of these purge jobs? Or do I just not understand the GUI?
In my opinion, at least the following jobs are affected:
as they are listed with different descriptions in CS > Server > Admin > Job Browser and in RME > Admin > System Preferences > Job Purge I list both descriptions:
Jobs which keeps ....
instances of Jobs:
JobID - CS - RME
1017 - CDAPurgeJob - Credential Verification Jobs
1040 - ReportJobPurge - Reports Jobs
1042 - ReportArvPurge - Reports Archives
no instances of Jobs:
1021 - PURGEJOB - Software Management Jobs
1024 - PurgeJobNetConfigJob - Netconfig Jobs
1026 - PurgeJobArchiveMgmt - Archive Management Jobs
1028 - PurgeJobArchiveUpdate - Archive Update Jobs
1030 - PurgeJobArchivePoller - Archive Poller Jobs
1032 - PurgeJobArchivePurge - Config Archives
1034 - PurgeJobConfigEditorJob - Config Editor Jobs
1036 - PurgeJobCwConfig - ConfigCli Jobs
1044 - PurgeJobNetShow - Netshow Jobs
Instances, but History seems to be deleted like the policy:
1033 - ICServerPurgeJob - Inventory Collector Jobs
1039 - InvPollerPurgeJob - Inventory Poller Jobs
jobId not in RME but listed in CS with Instances starting with xxxx.1
1018 - CDAPurgeJob [duplicate of 1017 ?]
1038 - ReportJobPurge [duplicate of 1040 ?]
1041 - ReportArvPurge [duplicate of 1042 ?]
Joe Clarke Wed, 07/08/2009 - 09:36
You are correct, purge jobs shouldn't be creating instance trails as there is no one to purge the purgers. This wouldn't be the first inconsistency with RME purge jobs. I suggest you work with TAC to get a bug filed on this.
