Change dial timeout
Tomoo Esaka Tue, 07/07/2009 - 12:21
In CCA 2.0 or above, you can change the interdigit timeout by going to Configure > Telephony > Dial Plan Outgoing > Digit Collection Timeout. When the timer expires, users will hear a fast busy tone. They can then hang up the handset or press End call softkey to revert to main screen. If they are doing on-hook dialing they can also press "Cancel" softkey to revert back to main screen.
Be sure to select "Save Configuration" when ayou re sure you have the correct setting applied.
