yjdabear Tue, 07/07/2009 - 12:03
  • Gold, 750 points or more
For the first part, it can be found either on the CM tab of the LMS portal in the Discrepancies pane under "Port is in Error Disabled State", or generate it on-the-fly via Campus Manager - Reports - Report Generator - Campus Manager Reports + Discrepancies - Available Types: Port is in Error Disabled State.
