07-07-2009 01:37 PM
Hi all,
After configuring ntp server, the time is syncronized with no problem at all.
The issue occurs when the router reloads/turns off, and when it goes up, the hour in the NM-WAE, will never sync automatically.
I always have to delete the ntp configuration line and re-apply it manually.
Any ideias ?
Plataform: NME-WAE-302 and NME-WAE-502.
Software Version: 4.1.1c.16
Best Regards,
Bruno Petrónio
07-07-2009 02:01 PM
Bruno,
I have not seen this. When you do a "show NTP Status" does it show that it's communicating with the router? What happens if you create a secondary NTP server that is available via the WAN?
Dan
07-07-2009 02:07 PM
Well,
Im not having access right now, but i will get that info.
Im configuring 1 only WAN ntp server, in Central Site. I could try to configure the router as the server, just for testing.
Cmpts,
Bruno Petrónio
07-08-2009 06:53 AM
Here it is a brand new example :
wae1#show version
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2008 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.1.1c (build b16 Nov 5 2008)
Version: nme-wae-302-4.1.1c.16
Compiled 10:10:31 Nov 5 2008 by cnbuild
System was restarted on Fri May 5 01:00:53 2006.
The system has been up for 1 hour, 38 minutes, 30 seconds.
wae1#show ntp status
ntp enabled
ntp authentication disabled
server list:
Server Key
10.10.210.248 -
remote refid st t when poll reach delay offset jitter
ama-dc01.lc.pt lclx-dc01.lc.pt 2 u 13 128 377 32.331 1002714 4.829
wae1#ping 10.10.210.248
PING 10.10.210.248 (10.10.210.248) 56(84) bytes of data.
64 bytes from 10.10.210.248: icmp_seq=1 ttl=123 time=22.7 ms
64 bytes from 10.10.210.248: icmp_seq=2 ttl=123 time=33.7 ms
64 bytes from 10.10.210.248: icmp_seq=3 ttl=123 time=27.7 ms
64 bytes from 10.10.210.248: icmp_seq=4 ttl=123 time=25.9 ms
--- 10.10.210.248 ping statistics ---
5 packets transmitted, 4 received, 20% packet loss, time 3998ms
rtt min/avg/max/mdev = 22.798/27.572/33.787/3.999 ms, pipe 2
wae1#
wae1#show clock
Local time: Fri May 5 02:43:15 WEST 2006
wae1#
Any ideias?
Best Regards,
Bruno Petrónio
07-08-2009 08:51 AM
Bruno,
Please validate, is it when you reload your local router (and NME) when the time synch difference occures? Also, it seems that it's with multiple NME-WAEs or just a couple? Do you see any syslog messages referencing NTP after boot?
Dan
07-08-2009 09:13 AM
Tks Daniel,
Yes, only when i reload the router.
I have 1 NME in each router only.
Syslog:
2006 May 5 00:01:51 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330082: [CLI_VER_NTP] requests stop service ntpd.
2006 May 5 01:02:18 Vimioso-wae1 ver_ntp: %WAAS-NTP-4-340008: failed to pre-sync system time and calendar.
2006 May 5 00:02:18 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330080: [CLI_VER_NTP] requests start service ntpd
2006 May 5 00:04:09 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330040: Start service 'ntpd' using: '/usr/sbin/ntpd -g -p /etc/ntpd.pid' with pid: 4524
2006 May 5 01:04:09 Vimioso-wae1 ntpd[4524]: %WAAS-NTP-5-340000: ntpd 4.0.99j Wed Nov 5 11:35:54 PST 2008 (1)
2006 May 5 01:04:09 Vimioso-wae1 ntpd[4524]: %WAAS-NTP-5-340000: using kernel phase-lock loop 0040
2006 May 5 02:41:18 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330032: Stopping service: 'ntpd'.
2006 May 5 03:41:18 Vimioso-wae1 ntpd[4524]: %WAAS-NTP-5-340000: ntpd exiting on signal 15
2006 May 5 02:43:46 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330082: [CLI_VER_NTP] requests stop service ntpd.
2006 May 5 03:44:12 Vimioso-wae1 ver_ntp: %WAAS-NTP-4-340008: failed to pre-sync system time and calendar.
2006 May 5 02:44:13 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330080: [CLI_VER_NTP] requests start service ntpd
2006 May 5 02:46:04 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330040: Start service 'ntpd' using: '/usr/sbin/ntpd -g -p /etc/ntpd.pid' with pid: 4604
2006 May 5 03:46:04 Vimioso-wae1 ntpd[4604]: %WAAS-NTP-5-340000: ntpd 4.0.99j Wed Nov 5 11:35:54 PST 2008 (1)
2006 May 5 03:46:04 Vimioso-wae1 ntpd[4604]: %WAAS-NTP-5-340000: using kernel phase-lock loop 0040
2006 May 5 03:02:32 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330084: [CLI_VER_NTP] requests restart service ntpd
2006 May 5 03:02:32 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330032: Stopping service: 'ntpd'.
2006 May 5 04:02:32 Vimioso-wae1 ntpd[4604]: %WAAS-NTP-5-340000: ntpd exiting on signal 15
2006 May 5 03:02:32 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330040: Start service 'ntpd' using: '/usr/sbin/ntpd -g -p /etc/ntpd.pid' with pid: 11047
2006 May 5 04:02:32 Vimioso-wae1 ntpd[11047]: %WAAS-NTP-5-340000: ntpd 4.0.99j Wed Nov 5 11:35:54 PST 2008 (1)
2006 May 5 04:02:32 Vimioso-wae1 ntpd[11047]: %WAAS-NTP-5-340000: using kernel phase-lock loop 0041
2006 May 5 03:27:47 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330082: [CLI_VER_NTP] requests stop service ntpd.
2006 May 5 03:27:47 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330032: Stopping service: 'ntpd'.
2006 May 5 04:27:47 Vimioso-wae1 ntpd[11047]: %WAAS-NTP-5-340000: ntpd exiting on signal 15
After this line i inserted manualy...
2009 Jul 8 16:39:08 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330080: [CLI_VER_NTP] requests start service ntpd
2009 Jul 8 16:39:08 Vimioso-wae1 Nodemgr: %WAAS-NODEMGR-5-330040: Start service 'ntpd' using: '/usr/sbin/ntpd -g -p /etc/ntpd.pid' with pid: 20238
2009 Jul 8 17:39:08 Vimioso-wae1 ntpd[20238]: %WAAS-NTP-5-340000: ntpd 4.0.99j Wed Nov 5 11:35:54 PST 2008 (1)
2009 Jul 8 17:39:08 Vimioso-wae1 ntpd[20238]: %WAAS-NTP-5-340000: using kernel phase-lock loop 0041
