ASA capability question
scott.bridges
I have an ASA 5505.
Primary ISP is a T1.
Secondary ISP is a Cable connection.
I remember reading that a PIX was able to do a failover type setup with this setup. Setting up a timer that would ping a destination, and if that IP stopped responding it would inject the Secondary ISP's route.
Is this possible with this ASA 5505?
branfarm1
Level 4
Level 4
Hi Scott,
Yes -- as far as I know, this should be possible with the ASA 5505. The feature you are looking for is called Static Route Tracking.
See these two pages:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ip.html#wp1090243
One difference you should see on the 5505 from the other 5500 models is that you are using VLAN interfaces instead of physical interfaces. You just assign the physical switch ports to be members of the seperate VLAN's.
Good luck!
--Brandon
8 Replies 8
branfarm1
Level 4
Level 4
Hi Scott,
Good luck!
--Brandon
Thanks Brandon,
Just one clarification question. Perhaps I should have mentioned this in original post:
I found this conversation in regards to Failover/DualWAN on this 5505:
"First we need to understand some limitations of our devices. The ASA5505 can only perform Active/Standby failover and not Active/Active. If you need that, you will have to look at a higher range device. Also they can only perform LAN-Based Failover (as opposed to old pixes that can use cable based failover) and they don't support Stateful Failover (meaning all active connections will be lost after a failover event). Also both units must have the same hardware, software configuration, and proper license and run in same mode (single or multiple, transparent or routed)."
Does this affect my goal? This 5055 should support my goal setup, correct?
Scott, Active/Standby or Active/Active is referring to device redundancy. Since the 5505 doesn't support multiple contexts, the best you could do is stateless-failover with a standby 5505. Of course, that also means you'd have to have the Security Plus license for your 5505, as the base license doesn't support stateless Active/Standby.
You should still be able to implement the static route tracking feature.
--Brandon
Thanks again Brandon.
Below is the output of my "show version" on the questioned ASA5505. I created Vlan3 to be the "backup" but when I do "nameif backup" it gives me a licensing error.
Which license do I need to purchase in order to nameif this Vlan and be able to implement the State Route Tracking feature? Also, should I be worried about this "no forward" command requirement?
Thanks again.
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 50
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
ciscoasa(config-if)# nameif backup
ERROR: This license does not allow configuring more than 2 interfaces with
nameif and without a "no forward" command on this interface or on 1 interface(s)
with nameif already configured.
It looks like you have the base license. If you had the Security Plus license, you should see "VLANs: 20" and "Failover: Enabled"
Okay,
I'm sorry to seem like I'm going in circles, but I would like to clarify before I tell a client to spend $595 on this Security Plus license.
I have a T-1 (1.1.1.10 WAN)
I have a Cable connection (2.2.2.10 WAN)
I have an ASA5505 (192.168.1.1 LAN)
If we purchase the Security Plus license, I will be able to implement the "route tracking" feature. This will track the T-1 connections primary route, and in the case of it going down, this feature will then inject the Cable connection's primary route as the "ip route".
This will act as an ISP failover. If our T-1 goes down, the ASA (and therefore, the client), will still be online through the Cable connection.
Is this correct?
Yes that's correct.
