View device logs in CSMARS
Answered Question
Jul 8th, 2009
Is there a way to view all the device logs collected by CSMARS on MARS GUI interface. Is so, how can it be done ?
Correct Answer by sadbulali about 7 years 7 months ago
Go to the query Page -> select the "All matching events" or "All matching raw messages" and click Reporting device filed, select the ASA device You can see all the events from the particular ASA only
STEPS TO VIEW FOR THE ENTIRE DEVICE
Click on the Query/Reports Tab
Edit the Query Type
Change Result Format to "All Matching Events" or "All Matching Events Raw Messages"
Select the Time parameters of your query (past 1 day, or date range, or real time, etc.)
Click Apply
Click on "ANY" under the Device field of the query Change the "All Variables" drop down to "All Reporting Devices" or a specific device type.
Add the specific device(s) to the left column and remove "ANY"
Click Apply
Click on Submit Inline to run the query
Overall Rating: 5 (1 ratings)
Correct Answer
sadbulali Tue, 07/14/2009 - 13:07
Edit the Query Type
Click Apply
Click Apply
