AP1250 Stops Broadcasting
Jul 8th, 2009
I have an LAP1250 that was running fine for about a year. then about three weeks ago users reported no or low signal strength. After looking at netstumbler, I discovered that the AP was not broadcasting and the users were attaching to an AP way down the office. I reset the AP and then after about a week it stopped broadcasting again and when looking at netstumbler the MAC is listed as not detected. Looking at the AP through the WLC it shows enabled UP but no one can associate to it. Looking at the client list on WLC there are a couple of clients listed as associated but, the linktest fails so, i assume that they are really not associated.
I am never really sure when is stops so, i cannot find anything in the logs and the device is not under warranty,
Any suggestions on troubleshooting this issue would be appreciated.
dancampb Wed, 07/08/2009 - 05:54
  • Cisco Employee,
There were a few bugs on this. When the AP is in this condition check the output of "show controller" and see if probes and beacons are disabled for the radio. Most of these bugs have been resolved in the latest versions of code posted to Cisco.com.
tkuzma1022 Wed, 07/08/2009 - 06:08
OK, thanks for the tip however, I don't see a 'show controller' on the command line of the WLC 4402. When I do a monitor/ap/radio's from the WLC webpage, the AP's radio's are listed as UP
What codes are the bugs in? I am running WLC 4.2.130.0 (AP IOS 12.4(10b)JA4)
dancampb Wed, 07/08/2009 - 06:57
  • Cisco Employee,
You need to run the 'show controller' on the AP itself. You can either console into the AP or use the remote AP debugs from the controller's CLI.
ericgarnel Wed, 07/08/2009 - 10:19
  • Gold, 750 points or more
You can also do the following:
controller>config ap ssh enable
controller> config ap mgmtuser add username password secret all|
ssh @
show controllers
tkuzma1022 Thu, 07/09/2009 - 07:28
Thanks for the ssh tip. I am on the AP and waiting to see what the beacon and probe status' are when it stops.
If this is the case the only way to reset the AP is a restart correct?
Then my next step will be to update the WLC code
Thank-you ALL for your help.
ericgarnel Thu, 07/09/2009 - 07:33
If it is on a switch with enhanced PoE, you can bounce the switchport or bounce the AP from WCS or the WLC
TKUZMA1022_2 Tue, 07/13/2010 - 05:50
Nothing other then the relys posted. I will say that I have not seen this issue since that time. I have done several 'code' updates since then and none if my AP1250's have had a problem since. I am currenly running 6.0.196.0
Leo Laohoo Tue, 07/13/2010 - 15:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Cisco is recommending everyone to stay away from 5.X and 6.X and upgrade instead to 7.X.
Vinay Sharma Sun, 05/29/2011 - 07:34
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
