CCX 7.0 license file was not uploaded
Jul 8th, 2009
After calling Cisco to get the license file I have added it into the Unified Contact Center Express Administration setup page. I get the following message:
" Error the license xxxxx.lic ,was not uploaded since SQL2K should be installedto enable High Availability feature. Please add High Availability server license after installing SQL2K".
I have checked the CCX server and restarted the SQL server/services.
Does anybody know what is wrong and how to fix it?
Thanks in advance,
Ruben de Haas
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Wed, 07/08/2009 - 11:38
  • Cisco Designated VIP,
    2017 IP Telephony
CCX uses MSDE by default. If you want to enable HA you must install SQL 2000 which ships on a separate disc first. If you have done this and are still getting an error, call TAC.
rubendehaas Thu, 07/09/2009 - 04:41
Ok, thanks for you're reply. After a reinstall I still get error messages. I will contact TAC.
