Is FAC (Forced Authorization Code) an official feature of UC?
Jul 8th, 2009
When browsing thru the UC administrator guide, i cant find any info about FAC (Forced Authorization Code) not Feature Access Code. But i have come across documents on how to setup FAC on UC (Customer script and built-in script).
Customer of my is hoping to have control over the phones by enforcing PIN codes for long distant and international calls, for security purpose. Can this really be done in UC?
Best regards,
Lawrence Chew
wfchew2007 Wed, 07/08/2009 - 08:01
I have this document, just that when i follow exactly it doesn't seem working. And why there is a need to dial-peer voip? My environment is to pots.
Why the administrator guide document doesn't have any feature such as FAC in it? Is this NOT an official feature of UC?
Best regards,
Lawrence Chew
Skyler Spence Wed, 07/08/2009 - 08:34
  • Bronze, 100 points or more
The VOIP dial peer is required for this feature to work.  Notice: Ensure that the destination pattern under your POTS dial-peers match the destination pattern shown above. If the POTS peer pattern is more specific, the loopback VOIP peer could be skipped.  So your existing POTS dialpeers will be used, just make sure that the destination patterns match.  Notice that in the VOIP dialpeer the target is 10.1.1.1.  If you believe that you have setup this feature correctly, please attach a copy of your configuration and I will check it for you.
wfchew2007 Wed, 07/08/2009 - 08:53
I dont have a working configuration of this yet. So as you have just mentioned, i need to create an interface lookpack, and create dial-peer voip and dial-peer pots with the same destination-pattern. Will try it and let you know.
Can i do only with PIN without the username ? Please advise.
Best regards,
Lawrence Chew
wfchew2007 Wed, 07/08/2009 - 19:57
Hereby is my working configuration; Caller need to dial access code of 5, then following the number. I noticed couple of issues with this implementation;
1. occassionally, no PIN prompted when dialing or re-dialing.
2. no prompt of re-enter of PIN if wrongly by accidently. Silent disconnect.
application
  service clid_authen_collect
  param uid-len 4
  param pin-len 4
dial-peer voice 5000 voip
description ** PINs TEST **
destination-pattern 5T
session target ipv4:10.1.0.1
incoming called-number 5T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 5010 pots
translation-profile incoming mapping
translation-profile outgoing outgoing_calls
direct-inward-dial
port 0/0/0:15
Best regards,
Lawrence Chew
Marcos Hernandez Thu, 07/09/2009 - 09:58
  • Blue, 1500 points or more
To resolve 1), add this under your POTS dial peer:
preference 5
2) is a system limitation, mentioned in the page referenced by Skyler.
Marcos
