Issue with ESMTP Inspect on ASA and Sophos appliance
Jul 8th, 2009
Anyone ever experienced an issue where your Sophos appliance that sits behind the ASA firewall cannot make a TLS connection outbound due to the ESMTP inspect option?
I don't want to disable it entirely. Is there a way to create a policy map to disable ESMTP inspection for just the Sophos appliances?
drolemc Wed, 07/15/2009 - 05:32
  • Silver, 250 points or more
If you use Transport Layer Security (TLS) encryption for e-mail communication then the ESMTP inspection feature (enabled by default) in the PIX drops the packets. In order to allow the e-mails with TLS enabled, disable the ESMTP inspection feature as this output shows.
pix(config)#policy-map global_policy
pix(config-pmap)#class inspection_default
pix(config-pmap-c)#no inspect esmtp
pix(config-pmap-c)#exit
pix(config-pmap)#exit
