cisco compatible extentions program (CCX)
Answered Question
Jul 8th, 2009
Hi every body!
My book says the following:
"Wlan clients may use wireless NIC from a large number of vendors. to help ensure that the clients can work with cisco APs, Cisco started the cisco compatible extentions program."
Let say i want to set up wireless lan using cisco Ap .
Let say i bought a wireless NIC which is CCXv1 certified.
CCXv1 has following features:
basic 802.11 and wi-fi compatibility
802.1x authntication for leap
multple ssids use.
Now i have to find cisco AP with which atleast supports the above mentioned features. Is my concept correct?
Thanks and have a nice day!
Correct Answer by Leo Laohoo about 7 years 6 months ago
HI Zeeshan,
Cisco AP's are backward compatible. Meaning, if you use a AP1130, it can see CCXv1 to CCXv5. You don't need to find a Cisco AP that will support one specific CCX version. On the contrary, CCX versions are dependent on the drivers of your wireless NIC.
Cisco Compatible Extensions Client Devices
http://www.cisco.com/web/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
Cisco Compatible Extensions Program Q&A
http://www.cisco.com/web/partners/pr46/pr147/partners_pgm_qandas09186a0080154625.html
CCX Versions and Features
http://www.cisco.com/web/partners/pr46/pr147/program_additional_information_new_release_features.html
Hope this helps.
By the way, this topic should've gone to the Wireless - Mobility section. Cheers!
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Wed, 07/08/2009 - 14:47
HI Zeeshan,
Hope this helps.
sarahr202 Fri, 07/10/2009 - 06:49
Thanks Leolaohoo. Sorry about posting question in wrong forum. I am preparing for ccnp routing exam and it was in my book.
thanks and have a nice weekend!
