Command accounting with ACS
Jul 8th, 2009
HOw can I achive command accounting via acs I have configured devices as below but no luck
aaa accounting exec aaa-list start-stop group bwaaa
aaa accounting commands 1 aaa-list start-stop group bwaaa
aaa accounting commands 15 aaa-list start-stop group bwaaa
aaa accounting system default start-stop group bwaaa
any idea about it
Jagdeep Gambhir Wed, 07/08/2009 - 10:12
  • Red, 2250 points or more
Command accounting only works with tacacs and not with radius. Make sure bwaaa is set up as tacacs.
These logs are stored in tacacs administration report, so make sure you are checking the correct head.
Still it is not working then check acs code. Incase it is 4.1.1 then you need to apply patch 5 to fix it.
To download patch for appliance,
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
For windows
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
~JG
Do rate helpful posts
jain.nitin Wed, 07/08/2009 - 10:51
Hi, I am using 4.2 version appliance. I am using tacacs+ u can s below config for your reference
aaa new-model
aaa group server tacacs+ bwaaa
server 10.2.6.1
server 10.2.6.2
ip tacacs source-interface Vlan1111
aaa authentication login aaa-list group bwaaa local
aaa authentication enable default group bwaaa enable
aaa authorization exec aaa-list group bwaaa local
aaa session-id common
tacacs-server host 10.2.6.1 timeout 25
tacacs-server host 10.2.6.2 timeout 25
tacacs-server timeout 25
tacacs-server directed-request
tacacs-server key cisco123
Jagdeep Gambhir Wed, 07/08/2009 - 12:06
As stated in other post, try it without any method list and get the debugs
debug aaa accounting
debug tacacs
Did you check tacacs administration logs??
jain.nitin Thu, 07/09/2009 - 11:12
HI It worked when I did not use any method list with the default list it works.. I dont understand why it is not working with my defined list...is there any other procedure to define method list..
