FWSM & IP Sec VPN module configuration
Jul 8th, 2009
Hi All,
we have a 7609 chassis where we have installed the FWSM module and IPsec VPN module.
we would like to configure a Site to Site VPN.
how do we do that now ?
Below is the VLAN interface
configuration (outside)on the fwsm
interface Vlan601
description INTERNET CONNECTION
nameif INTERNET
security-level 0
ip address x.x.x.x 255.255.255.248 standby x.x.x.x
thanks.
jeromecandiff Wed, 07/08/2009 - 10:38
First be sure that you are not using Security Contexts.
Other than that, the L2L VPn setup is exactly the same as it is on an Pix or an ASA.
Define your isakmp policies, specify the VPN interface, transform set, crypto map, tunnel group, and no nats (if necessary).
You can use this as a guide:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080950890.shtml
