SDM and Config Editor
Jul 8th, 2009
While enabling the firewall in SDM, it wiped out the cmd "login local" on my "line con 0". I am not able to find a tool in SDM to add the cmd back in except for ConfigEditor, but I do not know the syntax. I just want to be able to merge the new command back into my running config.
Giuseppe Larosa Thu, 07/09/2009 - 09:27
Hello Steve,
if you have telnet or ssh access to the box you can use CLI
telnet box-address
use the user/pwd needed
get enable access
router> enable
router# conf t
router(config)# line con 0
router(config-line)# login local
router(config-line)#end
test console access then if everything is fine:
router# write mem
a username/pwd pair must exist to use this.
Hope to help
Giuseppe
