T1 up/down
Jul 8th, 2009
  • Bronze, 100 points or more
Getting up/down on interface and the configs are right because I've configure over 50 sites with the same configs and they work.
What can I look for? Below are the configs I've been using:
interface Serial0/0/0
bandwidth 1536
ip address 10.1.1.1 255.255.255.252
ip accounting output-packets
encapsulation ppp
service-module t1 timeslots 1-24 speed 64
description MPLS Circuit -
service-policy output ETMS
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
service-module t1 fdl both
I don't think the problem is on my end but I've been wrong before.
Can the smart jack cause this also? I've had this happen in my lab were I used the wrong cable.
Thanks.
Overall Rating: 5 (1 ratings)
Rick Morris Wed, 07/08/2009 - 12:27
  • Silver, 250 points or more
Yes. What you have here is you see the wic but you do not see the circuit.
1. Make sure the cable from the router to the smartjack is good and correct pin out.
2. Make sure the carrier can loop up the smartjack and verify the circuit is good.
I would work with the carrier and have them provide you a loop from the smartjack facing you and see if you see a loop. Most of the time the issue is with the carrier on a condition like this, assuming you have your cables right.
DialerString_2 Wed, 07/08/2009 - 12:44
They are able to loop the smart jack.
Serial0/0/0 is up, line protocol is down (looped)
I get the above
Rick Morris Wed, 07/08/2009 - 12:46
then you are seeing the circuit so you are able to see up to the smartjack but not beyond that. verify encapsulation and line coding and framing. If they say they are good you just need to make sure you are both set up for the same coding/framing and encap.
DialerString_2 Wed, 07/08/2009 - 12:55
Just got off the horn with the provider the problem resides in their network. She said it was a cabling issue.
Thanks for the responses and I appreciate the input.
cisco steps Wed, 07/08/2009 - 14:59
When the loop is present you need to see what encap you are using if you using PPP you need change the encap to hdlc. then you will see Up/Up.. that will verify that your side is good... just more info to prove that the problem does not reside on your side, you can also do a hard loop on the back on the router to eliminate the WIC ..
Hope this helps
DialerString_2 Thu, 07/09/2009 - 08:02
the link slmansfield provided was extremely helpful as were all the post and yours. I tried changing the encap also but we got it working.
