Adding a new CallManager PIM
Jul 8th, 2009
Hello Forum,
Is through ICM setup the only way to add a new PIM (CallManager)? Because I don't see how I can do it in Configuration Manager.
david.macias Wed, 07/08/2009 - 12:22
You will have to configure it in config manager, under the PG. Then install it using the ICM setup.
fbushiri1 Thu, 07/09/2009 - 09:30
Thanks David,
I already have CallManager as a peripheral in Configuration manager. So I will just go to ICM setup and add another PIM I supposed. Because if I remember correctly from training is that ICM setup stops service. So I have to do this after hours.
