Ciscoview unable to view FWSM
Jul 8th, 2009
Dear friends,
When trying to view FWSM in CiscoView, i get the following error
Message
Can't find applicable device package for 172.20.1.12.
Cause
Device package for this device type is not installed or device support for this device type might not be available or you are attempting to open a component inside a device.
Action
Please install a device package for the device type or open the parent device to manage the component.
The following are the FWSM details:
Version: 4.0(3)
SysObjectiD: :enterprises.9.1.674
CiscoView version is 6.1.5 and the LMS Version is 2.6.
Can you suggest a solution for this?
Thanks a lot
Gautam
