UC 500 - CLI for outgoing calls
Jul 8th, 2009
Could anybody confirm that the number field under the ephone-dn is used to populate the CLI field for an outgoing Q931 call? I'm having difficulties using different CLI values for different phones and I want to double check I'm manipulating the correct field.
For example, in the ephone-dn below should I see 01234 123456 as the CLI?
ephone-dn 21 dual-line
number 01234 123456 secondary 212
label 01234 123456
description Desk Twelve
name Desk Twelve
call-forward busy 100
call-forward noan 100 timeout 10
jedellerby Wed, 07/08/2009 - 13:28
Typical, as soon as I post something I find the answer. I need to focus on the dial plan a little more and look at my translation-rule statements I now see:
voice translation-rule 1111
rule 15 /.*/ /01234 123456/
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
Can I simply remove the translate calling statement?
I'm not 100% sure how the DNs need to be configured yet as each phone will have a DDI when logged in via EM.
Paolo Bevilacqua Wed, 07/08/2009 - 14:19
Yes, basically you use the translation rules to present the correct calling number.
The alternative is to use "dialplan-pattern" but I don't like it very much beside it causes issues with the CUE if you have it.
jedellerby Thu, 07/09/2009 - 14:07
Thnaks, I sorted this today so now it's working fine.
I did have a quick go at trying a translation profile on the ephone-dn for the outgoing CLI but it didn't seem to work. It was along the lines of:
ephone-dn 8 dual-line
number 504 no-reg primary
label 504
description abc
name abc
translation-profile outgoing TRANSLATE-CLI
but I never got any match against the CLI for the outgoing call. Am I missing anything here?
Paolo Bevilacqua Fri, 07/10/2009 - 04:43
I've seen images where translation-profile under ephone-dn simply doesn't work.
Try to have it under dial-peer or voice-port as long as possible.
