strange RIP issue
Jul 8th, 2009
please see below output, default route stuck in VPN routing table for 15:46:40 although the ' Hold down timer expires in 0 secs'. has anyone expirienced this problem? is this normal practice on Cisco router? thanks
r0#sh ip ro vrf 504-ten 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "rip", distance 120, metric 4294967295 (inaccessible), candidate default path
Redistributing via rip, bgp 65500
Advertised by rip (self originated)
bgp 65500 route-map weight-0-local-pref-800
Last update from 10.250.41.86 on Serial1/0.1/1/6/3:0, 15:46:40 ago
guruprasadr Thu, 07/09/2009 - 06:05
  • Gold, 750 points or more
HI Kevin,
Can you post 'show ip rip database' will help watch the information.
In a normal scenario, The route will remain as "inaccessible" until the flush timer expires. Then it's gone...
Best Regards,
Guru Prasad R.
kevin.shi Thu, 07/09/2009 - 06:15
thanks for your input.
I have reset RIP config, because it was affecting service for 15 hours.
flush timer is 240 secs. The route was not gone as expected. is it a bug?
r0#sh ip pro vrf 504-ten
Routing Protocol is "rip"
Outgoing update filter list for all interfaces is 59
Incoming update filter list for all interfaces is not set
Sending updates every 30 seconds, next due in 20 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: static, rip, bgp 65500
