CISCO 6509 VLANS
I have created three vlans
VLAN 100
VLAN 200
VLAN 300
The cisco 3550 are configure with each respective vlan 100, 200, and 300.
As soon as I plug the switch on the fiber module, I notices the switch been added to the proper VLAN. I have execute the command sh vlan 100, and it shows the switches configure for vlan 100. The same thing for vlan 200 and 300.
However, I notices some switches were added to the wrong vlans. Is there a command or configuration that I am doing that is causing this issue?
Overall Rating: 5 (5 ratings)
Jerry Ye Wed, 07/08/2009 - 18:05
  • Cisco Employee,
Hi Pedro,
What do you mean by "some switches were added to the wrong vlans"?
What is your topology? And what VTP mode are you using on all the switches?
jerry
Yes, the vlans are configure as this:
VLAN 100 172.31.181.128/26
VLAN 200 172.31.181.192/26
VLAN 300 172.31.13.0/24
Each switch,from the different networks, connect to the core router thru fiber connection.
I have been creating the vlans on the
cisco switches using the script. Follow, I have included a sample configuration for each of the vlan configuration (VLAN 100, 200, and 300)
VLAN 100
ip domain-name lv.psu.edu
ip ssh version 2
int range f0/1 - 24
description academic
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport mode trunk
no shut
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface Vlan1
ip address 172.31.181.194 255.255.255.192
no shut
interface Vlan100
description Academic
no ip address
no ip route-cache
no shut
VLAN 200
ip ssh version 2
int range f0/1 - 24
description Administrative
switchport access vlan 200
no shut
interface Vlan1
no shut
interface Vlan200
ip address 172.31.181.130 255.255.255.192
no shut
ip classless
ip http server
ip http secure-server
VLAN 300
ip ssh version 2
int range f0/1 - 24
description Wireless
switchport access vlan 300
no shut
no shut
no shut
interface Vlan1
ip address 172.31.13.3 255.255.255.0
no shut
interface Vlan300
no ip address
no ip route-cache
no shut
ip classless
But, I'm not sure if it would work better to use vtp at each switch, or after configuring vtp server on cisco 6509, every switch will self join the appropiate vlan.
Jerry Ye Wed, 07/08/2009 - 18:36
  • Cisco Employee,
Hi Pedro,
I see that you are using Vlan 1 for management and not going configure IP addresses on interface Vlan100, Vlan200, and Vlan300. If this is the case, there is not need for interface Vlan100, etc on these switches.
So which switch is getting the wrong Vlan? Which command give you that impression, can you post the output of that also? Also, if you would post the output of the following three (3) commands on all the 3550's and the 6500's, it will be great:
show vtp status
show vlan
show int trunk
jerry
Jerry,
I will be doing this as soon as I get to work this morning.
1) DO you recommend using Manual VLAN script or creating them on each switch VTP Database?
2) As far switch vlan adding themselves to VLANS on CISCO 6509, when running the command sh vlan 100, it shows the vlan number and on the right hand, a list of fiber ports that I'm assumming are switches with pre-configure vlans.
Is this assumption correct?
Jerry Ye Thu, 07/09/2009 - 04:58
  • Cisco Employee,
Hi Pedro,
It is upto you which method you prefer, as long as they are correct.
From you description of the output, sound like the ports are assigned to the VLAN someone configured before. The only pre-configurated VLAN is really VLAN1 where it cannot be deleted.
HTH,
jerry
Jerry,
As you can see, I am including the information you have requested.
One issue we are having with the cisco 6509, the vlan are been set to native vlan 1. However, the switches are configured with 100,200 and 300, respectively.
How can I set on cisco 6509 to put this vlan 100,200 and 300 in the correct native vlan, instead of cisco deciding to pu them on native vlan 1?
CISCO 6509 --- Server
Console> (enable) sh vtp domain
Domain Name Domain Index VTP Version Local Mode
Password
lv.psu.edu 1 2 server -
Vlan-count Max-vlan-storage Config Revision Notifications
8 1023 0 disabled
Last Updater V2 Mode Pruning PruneEligible on Vlans
0.0.0.0 disabled disabled 2-1000
Console> (enable) sh vtp statistics
VTP statistics:
summary advts received 109
subset advts received 58
request advts received 0
summary advts transmitted 1320
subset advts transmitted 200
request advts transmitted 51
No of config revision errors 0
No of config digest errors 51
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from GVRP
PDU
non-pruning-capable device
Received
3/4 0 0 0 0
3/6 0 0 0 0
4/4 0 0 0 0
15/1 0 0 0 0
16/1 0 0 0 0
Console> (enable)
Console> (enable) sh vlan
VLAN Name Status IfIndex Mod/Ports, Vlans
1 default active 199 1/1-2
2/1-2
3/1-3
4/2-3,4/5-16
6/1-8,6/10,6/15-
48
7/1-32,7/34-48
100 academic active 205 3/5,3/7-16
200 admin active 204 7/33
300 wireless active 206 4/1
6/9,6/11-14
1002 fddi-default active 200
1003 token-ring-default active 203
1004 fddinet-default active 201
1005 trnet-default active 202
VLAN Type SAID MTU Parent RingNo BrdgNo Stp BrdgMode Trans1
Trans2
1 enet 100001 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
300 enet 100300 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - - - 0 0
1005 trbrf 101005 1500 - - - ibm - 0 0
VLAN MISTP-Inst DynCreated RSPAN
1 - static disabled
100 - static disabled
200 - static disabled
300 - static disabled
1002 - static disabled
1003 - static disabled
1004 - static disabled
1005 - static disabled
VLAN AREHops STEHops Backup CRF 1q VLAN
1003 7 7 off
Console> (enable)
CISCO 6509- Router
SRVRM-6509-MSFC1#sh run
Building configuration...
Current configuration : 3547 bytes
! Last configuration change at 08:52:47 EDT Thu Jul 9 2009
! NVRAM config last updated at 17:08:29 EDT Wed Jul 8 2009
version 12.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname SRVRM-6509-MSFC1
boot system bootflash:c6msfc2-psv-mz.121-13.E3.bin
boot bootldr bootflash:c6msfc2-boot-mz.121-13.E3.bin
no logging console
enable secret 5 $1$k3j8$vSFg2vXjmUMrtU/pxlCTX/
enable password 7 08121C430B0B0005424A
clock timezone EST -5
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
clock calendar-valid
ip subnet-zero
interface Loopback0
ip address 10.5.12.1 255.255.255.255
interface Vlan1
description Management VLAN
ip address 172.31.181.189 255.255.255.192
no ip redirects
standby 1 ip 172.31.181.129
standby 1 priority 120
standby 1 preempt
interface Vlan100
description Lab 214 VLAN
ip address 146.186.50.253 255.255.255.0
no ip redirects
standby 1 ip 146.186.50.1
standby 1 preempt
interface Vlan200
description LAB 200 VLAN
ip address 146.186.27.253 255.255.255.0
ip helper-address 146.186.27.3
no ip redirects
standby 1 ip 146.186.27.1
standby 1 preempt
interface Vlan300
description Wireless Lan
ip address 172.31.13.254 255.255.255.0
no ip redirects
standby 1 ip 172.31.13.1
standby 1 preempt
Console> (enable) sh vlan 1
2/1-2
3/1-3
4/2-16
6/1-8,6/10,6/15-48
7/1-32,7/34-48
15/1
16/1
VLAN Type SAID MTU Parent RingNo BrdgNo Stp BrdgMode Trans1 Trans2
1 - static disabled
Console> (enable) sh trunk
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
3/2 auto n-dot1q trunking 1
3/3 auto dot1q trunking 1
4/3 auto n-dot1q trunking 1
4/4 auto n-dot1q trunking 300
4/6 auto dot1q trunking 200
15/1 nonegotiate isl trunking 1
16/1 nonegotiate isl trunking 1
Port Vlans allowed on trunk
3/2 1-1005,1025-4094
3/3 1-1005,1025-4094
4/3 1-1005,1025-4094
4/4 1-1005,1025-4094
4/6 1-1005,1025-4094
15/1 1-1005,1025-4094
16/1 1-1005,1025-4094
Port Vlans allowed and active in management domain
CISCO 3550
___________________________________
Cisco 3550
LV-126B-AD-181-130#sh vtp
% Incomplete command.
LV-126B-AD-181-130#sh vtp st
LV-126B-AD-181-130#sh vtp status
VTP Version : 2
Configuration Revision : 10
Maximum VLANs supported locally : 1005
Number of existing VLANs : 8
VTP Operating Mode : Client
VTP Domain Name : lv.psu.edu
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0xD2 0xD9 0xE9 0xBA 0xA1 0x35 0xF7 0xBE
Configuration last modified by 172.31.13.4 at 3-1-93 00:07:39
LV-126B-AD-181-130#sh trunk
% Invalid input detected at '^' marker.
LV-126B-AD-181-130#sh vlan
VLAN Name Status Ports
1 default active Gi0/2
100 academic active
200 administrative active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
300 wireless active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
1003 0 0 off
Remote SPAN VLANs
Primary Secondary Type Ports
LV-126B-AD-181-130#sh int trunk
Gi0/1 on 802.1q trunking 200
Gi0/1 1-4094
Gi0/1 1,100,200,300
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1,100,200,300
LV-126B-AD-181-130#
Jerry Ye Thu, 07/09/2009 - 10:19
  • Cisco Employee,
Hi Pedro,
This is my observation:
1) Your 6500 is running as VTP server, and you've configured SVI for Inter-VLAN routing
2) Your 3550's are running as VTP client and L2
When you have VTP clients and attaching them to the VTP server, VTP server will copy its VLAN database into the clients when the revision number of the server is higher than the clients. (Just a side note, when the client's revision number is higher than the server, it will override the server's VLAN database, be careful with this!!!).
So I am assuming your concern is you don't want, example, VLAN 100 and 300 apprear on your switch - LV-126B-AD-181-130's VLAN database? If this is the case, you have to make all the switches as VTP transparent mode and configure each VLAN manually, and prune them manually. There is another solution, you might want to consider, where you can turn on VTP pruning, just use the command set vtp prun on you VTP server, 6500's CatOS. It will prune the traffic out of the trunk link.
HTH,
jerry
Jerry,
How come the vlans are showing, on the server, as native vlan 1.
How can I change this information?
Jerry Ye Thu, 07/09/2009 - 11:14
  • Cisco Employee,
Hi Pedro,
That is the native VLAN for the trunk port, default is VLAN 1. You can change it by using set trunk x/x 100 where x/x is your port and 100 is your VLAN number. You have to change both side of the trunk to match, otherwise the switches will complain about native VLAN mismatch. You have to be careful when you are changing this, native VLAN mismatch can cause a spanning tree loop.
HTH,
jerry
Jerry Ye Thu, 07/09/2009 - 11:44
  • Cisco Employee,
HI Pedro,
I don't have any switches with CatOS handy, but the configuration is very similar (with the set command):
C6500
vlan 100
vlan 200
interface FastEthernet3/1
description TO_3550_1
switchport trunk native vlan 100
interface FastEthernet3/2
description TO_3550_2
interface Vlan100
ip address 10.1.100.1 255.255.255.0
interface Vlan200
ip address 10.1.200.1 255.255.255.0
3550_1
interface FastEthernet0/1
description TO_C6500 3/1
interface range FastEthernet 0/2 - 24
interface Vlan100
description 3550_1 management
ip address 10.1.100.4 255.255.255.0
3550_2
description TO_C6500 3/2
switchport trunk native vlan 200
interface Vlan100
description 3550_2 management
ip address 10.1.200.4 255.255.255.0
HTH,
jerry
I think my configuration match to this configuration. We are able to have two switches working with the cisco 6509. Howeve, other switches on difeferent vlans 100 and 200 will not talk to the router.
The switches complaint the vlan mistmatch configuration. Therefore, on the router, the native vlan is set to 1 when it should be set to either 100 or 200 or even 300.
I'm not sure how the router can work fine with two swtiches but not the other switches. It is the same configuration on the rest of the switches.
My thinking is that there is something in the router that will not allow the other switches to work correctly.
Can you explain?
Jerry Ye Thu, 07/09/2009 - 12:06
  • Cisco Employee,
Hi Pedro,
You have to fix the native vlan mismatch first. This is can cause spanning tree loop which can lead to a network outage.
I saw your configuration has HSRP configured, do you have a 2nd pair of 6500? Also, Can your 3550's ping the default gateway? If not, make sure you have the following commands if the 3550's will be doing L2 only:
no ip routing
ip default-gateway x.x.x.1
HTH,
jerry
Jerry Ye Thu, 07/09/2009 - 17:15
  • Cisco Employee,
Hi Pedro,
The ip default-gateway command is for the switch management.
I don't suggest you to put the 3550's into server mode. You can leave them on client. If you've decided to changed the VTP mode to client from transparent, please make sure revision number is lower than the server.
jerry
Jerry Ye Thu, 07/09/2009 - 17:38
  • Cisco Employee,
Hi Pedro,
ip default-gateway is for the switch management. It has nothing to do with the host.
For example, when a host on VLAN100 is attached to the 3550, traffic will trunked to your 6500, if it wants to access anything outside VLAN100. It will use the ip address on the 6500's interface vlan 100 as its default router.
jerry
ok, let's start with my basic switch configuration. Can you critic or say if this is correct?
en
vlan database
vtp transparent
apply
exit
Config t
hostname LV-126B-AC-181-194
enable secret 5 $1$27ar$DnvrYBhnNW5eyTF2JgHIe.
enable password 7 0307585A5E5A744058
username admin password 7 1414115A54517F2732
!no aaa new-model
!ip subnet-zero
ip ssh version 2
int range f0/1 - 24
no shut
interface Vlan1
no shut
interface Vlan100
ip default-gateway 172.31.181.193
no shut
ip classless
ip http server
banner motd #
** WARNING: Unauthorized access to this system **
** is forbidden and will be prosecuted by law. **
** By accessing this system, you agree that your **
** actions may be monitored if unauthorized usage **
** is suspected. Only authorized Penn State **
** Lehigh Valley Campus **
line con 0
exec-timeout 0 0
line vty 0 4
password 7 1511085D5C7F7E283E
login local
transport input telnet ssh
line vty 5 15
password 7 094F4D584150421E1D
no login
end
wr
Jerry Ye Thu, 07/09/2009 - 17:51
  • Cisco Employee,
interface Vlan100
no shut
no ip routing
As far the cisco router, the OS version use set commands and not the latest cisco IOS. what do I need to eliminated or add to this configuration?
version 12.1
no logging console
ip subnet-zero
interface Loopback0
interface Vlan1
no ip redirects
standby 1 preempt
interface Vlan100
no ip redirects
standby 1 preempt
interface Vlan200
no ip redirects
standby 1 preempt
interface Vlan300
no ip redirects
standby 1 preempt
ip classless
ip route 146.186.27.0 255.255.255.0 172.31.181.129
ip route 146.186.50.0 255.255.255.0 172.31.181.193
ip route 172.31.13.0 255.255.255.0 172.31.13.1
no ip http server
access-list 101 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 102 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 103 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.0
access-list 105 permit ip 146.186.27.0 0.0.0.255 host 172.31.181.131
access-list 106 permit ip 146.186.27.0 0.0.0.255 host 172.31.13.10
access-list 107 permit ip 146.186.27.0 0.0.0.255 0.0.0.0 255.255.255.192
access-list 121 permit ip 172.31.181.0 0.0.0.255 172.31.13.0 0.0.0.255
snmp-server community BR0WSE RO
snmp-server community b0wl1ng RW
snmp-server community private RW
snmp-server community BROWSE RO
snmp-server enable traps snmp authentication warmstart
snmp-server enable traps slb real virtual csrp
snmp-server enable traps flash insertion removal
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps bgp
snmp-server enable traps rsvp
snmp-server enable traps frame-relay
snmp-server enable traps rtr
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps dlsw
snmp-server host 10.5.1.163 2
tacacs-server host 10.0.13.110
tacacs-server timeout 10
tacacs-server key 1cecacseng1key1
ntp clock-period 17179855
ntp source Loopback0
ntp master 2
ntp update-calendar
end
Jerry Ye Thu, 07/09/2009 - 18:09
  • Cisco Employee,
Hi Pedro,
I finally see what is the problem. On your 3550 LV-126B-AC-181-194, you cannot assign Vlan100 with the IP address of 172.31.181.194. The reason is this Vlan100 is the same Vlan100 on your 6500, they cannot be o different IP subnet. Also, which is your default gateway for management Vlan? Which router is 172.31.181.193? I can only see your default to be 172.31.181.129.
To get the 3550 to work, this is what you can do:
no interface vlan100
interface Vlan1
no shut
ip default-gateway 172.31.181.129
HTH,
jerry
Hi Jerry
I was assigned three subnets to manage the administrative switches, academic switches and the wireless switches.
Administrative switches 172.31.181.128/26
Academic Switches 172.31.181.128/26
Wireless Switches and APs 172.31.13.0/24
Do I use one address of the three subnets, or do I need to have a separate subnet for the router. And/or all network switches needs to be under one single subnet?
Jerry Ye Thu, 07/09/2009 - 18:28
  • Cisco Employee,
Hi Pedro,
Okay, let's talk about design. Since your Administrative switches and your Acadamic switches are in the same subnet, 172.31.181.128/26, they need to be on the same VLAN.
Since Wireless Switches and AP's are in 172.31.13.0/24, this need to be on a different VLAN.
I am assuming this is for management devices.
HTH,
jerry
ok,
If I understood correctly, the two subnets
172.31.181.128/26 and 172.31.181.192/26 needs to be let's say VLAN 200.
And, wireless network 172.31.13.0/24 on VLAN 300.
Now, before I carry away, I'm not sure if you notice the router has three vlans, 100, 200 and 300 with the gateway of each respective subnet.
thanks
Jerry Ye Thu, 07/09/2009 - 18:46
  • Cisco Employee,
Hi Pedro,
"172.31.181.128/26 and 172.31.181.192/26 needs to be let's say VLAN 200", these are two (2) different networks and they need to be on two (2) different VLAN, let's say 200 VLAN 201 and VLAN 202.
On your current 6500 configuration -
interface Vlan100
no ip redirects
standby 1 preempt
interface Vlan200
no ip redirects
standby 1 preempt
interface Vlan300
no ip redirects
standby 1 preempt
You are using VLAN100 for Lab 214 and VLAN 200 for Lab 200. You cannot reuse this VLAN ID for other address, this is the reason why the two (2) 3550's (VLAN100 and VLAN200) cannot take the the default gateway. VLAN300 is correct by comparing from the information you gave me.
HTH,
jerry
ok I think this is start making sense.
The vlans 100 - 200 - 300 on the cisco switch 3550's are configure differently than the Cisco 6509.
So, in order to fix this issue, I should have for example,
172.31.181.128/26 on vlan 400
172.31.181.192/26 on vlan 401
172.31.13.0/24 on vlan 402
Then, at the cisco router have the vlans created as follow
interface Vlan400
description Academic Switches
no ip redirects
standby 1 preempt
interface Vlan401
description Administrative switches
ip address 172.31.181.246
standby 1 ip 172.31.181.193
standby 1 preempt
interface Vlan402
description Wireless Lan Switches
no ip redirects
standby 1 preempt
Jerry Ye Thu, 07/09/2009 - 19:20
  • Cisco Employee,
Hi Pedro,
Good enough so far. You've forgot the network mask for Vlan401. So on the 6500's CatOS, you have to create Vlan 400, 401, and 402 also. Do the following command in CatOS
set vlan 400
set vlan 401
set vlan 402
This should do it. Also, You can leave your 3550's in VTP Client mode.
HTH,
jerry
interface Vlan1
no ip address
interface Vlan400
description Academic Network
no ip redirects
standby 1 preempt
interface Vlan401
description Administrative Network
no ip redirects
standby 1 preempt
interface Vlan402
no ip redirects
standby 1 preempt
interface Vlan100
no ip redirects
standby 1 preempt
interface Vlan200
ip address 172.31.181.246 255.255.255.192
standby 1 preempt
interface Vlan300
no ip redirects
standby 1 preempt
ip classless
no ip http server
ntp master 2
ntp update-calendar
end
Jerry Ye Thu, 07/09/2009 - 19:26
  • Cisco Employee,
Hi Pedro,
How come this is different from the script you gave me before?
Did you change Vlan400 to 146.186.50.253 255.255.255.0, Vlan401 to 146.186.27.253 255.255.255.0. Also, Vlan402 and Vlan300 has the same IP address.
jerry
Jerry Ye Thu, 07/09/2009 - 19:30
  • Cisco Employee,
Yes, on the three (3) new 3550's.
jerry
ok, this is a better look..
interface Vlan1
no ip address
interface Vlan400
no ip redirects
standby 1 preempt
interface Vlan401
no ip redirects
standby 1 preempt
interface Vlan100
no ip redirects
standby 1 preempt
interface Vlan200
standby 1 preempt
interface Vlan300
no ip redirects
standby 1 preempt
ip classless
no ip http server
ntp master 2
ntp update-calendar
end
Jerry Ye Thu, 07/09/2009 - 20:08
  • Cisco Employee,
Hi Pedro,
You are adding these new address blocks into the network, just create new VLAN's. Less downtime anyway.
HTH,
jerry
Hi jerry,
Now that I feel confortable with the MSFC1 configuration, moving to the other area of the router (console). After making the changes on the switches and the MSFC1, this session should start getting fix. Or, do you think there is something to be fixed?
Jerry,
Before I forget, the command entered in the switch for each of the port
int range f0/1 - 24
Because this command affects the hosts connecting to the port, then, it should be change to reflect the vlan the hosts have access.
In my router configuration vlan 100 is the subnet use to manage the switch.
The hosts are on a different subnet. Therefore, the swichtport mode access vlan 400 is the correct vlan for the all hosts pluggin to the switch.
thanks
Jerry Ye Fri, 07/10/2009 - 05:12
  • Cisco Employee,
Hi Pedro,
switchport access vlan 100 is for hosts.
In response to your previous email, port 4/4 and 4/6 are assigned to native vlan 200 and 300, I think you want this in VLAN100 since you said this is your management VLAN.
If you changed these two (2) ports to VLAN100, both side of the trunk should be matched to avoide native VLAN mismatch.
HTH,
jerry
Hi Jerry,
I have made good progress. Must of the network seems to be working.
Now, a few switches with the correct information and at the router they are configure with the correct native vlan, they are not able to ping the router or the router can't ping them.
Do you think spanning tree is causing any trouble?
Console> (enable) sh config
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Fri Jul 10 2009, 18:22:34
#version 7.3(1)
#vtp
set vtp domain lv.psu.edu
set vtp v2 enable
set vtp pruning enable
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 100 name academic type ethernet mtu 1500 said 100100 state active
set vlan 200 name administrative type ethernet mtu 1500 said 100200 state active
set vlan 400 name academic-network type ethernet mtu 1500 said 100400 state active
set vlan 401 name administrative-network type ethernet mtu 1500 said 100401 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active bridge 0x0 stp ieee
set vlan 1005 name trbrf-default type trbrf mtu 4472 said 101005 state active bridge 0xf stp ibm
set vlan 300
set vlan 1003 name trcrf-default type trcrf mtu 4472 said 101003 state active parent 1005 ring 0xccc mode srb aremaxhop 0 stemaxhop 0 backupcrf off
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat6000-sup2k8.7-3-1.bin
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 : 2-port 1000BaseX Supervisor
#module 3 : 16-port 1000BaseX Ethernet
set vlan 100 3/4-5,3/7-8,3/12-16
set vlan 200 3/2-3,3/9-11
set vlan 300 3/6
set udld enable 3/5
set trunk 3/3 auto dot1q 1-1005,1025-4094
clear trunk 3/13 100
set trunk 3/13 auto negotiate 1-99,101-1005,1025-4094
#module 4 : 16-port 1000BaseX Ethernet
set vlan 100 4/16
set vlan 200 4/6
set vlan 300 4/1,4/3-4,4/12
set udld enable 4/7-10
set trunk 4/1 auto dot1q 1-1005,1025-4094
clear trunk 4/6 300
set trunk 4/6 auto dot1q 1-299,301-1005,1025-4094
#module 5 : 0-port Switch Fabric Module
#module 6 : 48-port 10/100BaseTX Ethernet
set vlan 300 6/9,6/11-14
#module 7 : 48-port 10/100BaseTX Ethernet
set vlan 401 7/33
#module 8 empty
#module 9 empty
#module 15 : 1-port Multilayer Switch Feature Card
#module 16 : 1-port Multilayer Switch Feature Card
end
Console> (enable)
Jerry Ye Fri, 07/10/2009 - 10:44
  • Cisco Employee,
Hi Pedro,
Just make sure your native VLAN on the trunks is correct. Check your IP address. And lastly, check your configuration of ip default-gateway.
HTH,
jerry
Jerry Ye Fri, 07/10/2009 - 10:56
  • Cisco Employee,
Hi Pedro,
I am not familiar with the HP switch configuration. However, to interop with Cisco switch, as long as you are using open standard protocol for your trunk, 802.1q trunk, you should be fine.
HTH,
jerry
Jerry Ye Fri, 07/10/2009 - 13:11
  • Cisco Employee,
Hi Pedro,
You need to leave spanning tree on, otherwise you will have loop and it can cause outage to your network.
HTH,
jerry
Jerry Ye Fri, 07/10/2009 - 19:14
  • Cisco Employee,
Hi Pedro,
Sorry, I don't have experience with the wireless product, you can try the Wireless - Mobility group for more info.
jerry
