vpn-idle-timeout for L2L tunnels?
Jul 8th, 2009
On an ASA 5505,
Does the vpn-idle-timeout value in the default group policy apply to L2L tunnel groups?
As far as I knew, this parameter was only used for remote-access VPN configurations but since L2L tunnel groups reference this group policy by default, I'm curious to know if the idle-timeout value has any bearing on the L2L tunnel.
Todd Pula Thu, 07/09/2009 - 06:06
The vpn-idle-timeout as configured in the default group policy will impact L2L tunnels as well. The recommended configuration is to use a different group policy for your L2L tunnel groups where the idle timeout is set to vpn-idle-timeout none.
