How to configure rogue detector to scan all vlans ?
Answered Question
Jul 8th, 2009
I read the guide and found that, the rogue detector need to use trunk link connect to switch, does it means we need to change the native vlan respectively (vlan 1 won't be use in normal situation) and is there any special configuration need to do at rogue detector?
Correct Answer by ericgarnel about 7 years 10 months ago
the native vlan has to be the same that your management interface is in. You will then need to make sure that the controller is able to see the wired networks that the "on-wire" rogues could potentially be connected to.
Overall Rating: 0 (1 ratings)
Correct Answer
ericgarnel Wed, 07/08/2009 - 18:02
  • Gold, 750 points or more
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
