SIP Fax to email
Jul 8th, 2009
I am looking for a design guide or a config example that's taking inbound numbers from a SIP trunk and sending it to the onramp fax application. I have been able to get this to work in the past with PRIs but not luck so far with SIP. Thanks in advance.
natedog Mon, 07/13/2009 - 16:40
I have loaded the latest T.38 tcl fax detect script, has anyone had any luck getting this to work with inbound SIP trunk?
Nicholas Matthews Mon, 07/13/2009 - 19:46
Unfortunately T37 onramp isn't supported with an incoming voip dial-peer. The latest version of the fax-detect script can route it to a different number, however. Which are you looking to do?
