Unable to ping remote LAN ip using cisco VPN client for remote access
Answered Question
Jul 8th, 2009
Hi Folks,
I have a site to site VPN constructed using a Cisco 1841 and ASA 5520. The 1841 serve as a spoke and ASA 5520 is the hub. Now I would like to
turn on client remote access VPN on the 1841 with the config attached.For now, I am able to connect successful using the cisco VPN client but unable to ping
10.224.5.5 (cisco switch) or any 10.224.5.x devices. It is also noted that I was able to ping the loopback interface 10.234.1.23. Any idea what could be wrong?
Correct Answer by thotsaphon about 7 years 6 months ago
Chai Kok Soon,
What about this? (grin)
ip access-list extended nonat
no deny ip 192.168.1.0 0.0.0.255 10.0.0.0 0.255.255.255
deny ip 10.0.0.0 0.255.255.255 192.168.1.0 0.0.0.255
ip access-list extended [email protected]
no permit ip 192.168.1.0 0.0.0.255 10.0.0.0 0.255.255.255
permit ip 10.0.0.0 0.255.255.255 192.168.1.0 0.0.0.255
Please let us know how things work out
HTH,
Toshi
Correct Answer by xcz504d1114 about 7 years 6 months ago
It looks like your NAT statements are wrong.
So a remote user connects to the fa 0/0 interface, your nonat ACL is applied to that interface, it looks like it is written so that when 10.224.5.0 talks to anything with a deny, then it isn't NAT'd out.
You have a deny statement:
So what about when the 10.0.0.0 network wants to talk to the 192.168.1.0 network? It will be NAT'd.
Change that deny statement to read:
I don't believe you need the:
statement, as the direction is applied going outbound, but i may be wrong, you might want to test both, with it and without it.
HTH,
Craig
Overall Rating: 5 (2 ratings)
Correct Answer
xcz504d1114 Thu, 07/09/2009 - 08:52
HTH,
Craig
Correct Answer
thotsaphon Fri, 07/10/2009 - 06:15
Chai Kok Soon,
HTH,
Toshi
ChaiKokSoon Sun, 07/12/2009 - 16:15
Hi Toshi,
Thanks, the problem has been resolved as you and Craig have pointed out.
ChaiKokSoon Sun, 07/12/2009 - 16:13
Hi Craig,
Thanks for pointing it out and that resolve the problem.Much appreciated.
