AAA Authorization Using Local Database
Jul 8th, 2009
Hi Guys,
I'm planning to use AAA authorization using local database. I have read already about it, I have configured the AAA new-model command and I have setup user's already. But I'm stuck at the part where I will already give certain user access to certain commands using local database. Hope you can help on this.
FYI: I know using ACS/TACACS+/RADIUS is much more easy and powerful but my company will most likely only use local database.
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Thu, 07/09/2009 - 07:54
For allowing limited read only access , use this example,
We need these commands on the switch
Switch(config)#do sh run | in priv
username admin privilege 15 password 0 cisco123!
username test privilege 0 password 0 cisco
privilege exec level 0 show ip interface brief
privilege exec level 0 show interface
privilege exec level 0 show switch
No need for user to login to enable mode. All priv 0 commands are now there in the user mode. See below
User Access Verification
Username: test
Switch>show ?
diagnostic Show command for diagnostic
flash1: display information about flash1: file system
flash: display information about flash: file system
interfaces Interface status and configuration
ip IP information
switch show information about the stack ring
Switch>show switch
Switch/Stack Mac Address : 0015.f9c1.ca80
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master 0015.f9c1.ca80 1 0 Ready
Switch>show run
% Invalid input detected at '^' marker.
Switch>show aaa server
Switch>show inter
Switch>show interfaces
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 0015.f9c1.cac0 (bia 0015.f9c1.cac0)
Internet address is
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Please check this link,
Do rate helpful posts
helios999 Thu, 07/09/2009 - 18:11
Hi JG,
Thanks for your reply and it is very helpful. I just like to confirm that what you showed is using AAA authorization on local database, right?
helios999 Thu, 07/09/2009 - 21:24
Hi JG,
One more thing can you enlighten me about the command "privilege interface and privilege configure"? Or do you have a link that discusses this commands?
