Call Manager 6.1 with DL380G5
Jul 8th, 2009
hello,
i have a Server " HP ProLiant DL380 G5" with the following hardware specifications :
S/N: CZC8364LLT
Product ID: 458565-421
HP BIOS P56 08/03/2008
2048 Memory Configured
Proc 1: Intel 2.66 GHz, 12 MB L2 Cache
And while trying to install Cisco Unified Communication Manager 6.1(3),
After checking the media and passing this step, An Error appeared which is a critical error and it's attached and named as the "first image.
And after that, i insert a Hardware Detection CD "AVVID" and after a while, a new error appeared which is displayed as following :
"This OS version does not support the detected server
Remove the disk and press any key to reboot"
antonio.vazquez Thu, 07/09/2009 - 00:53
  • Bronze, 100 points or more
Have you ever been installed any Cisco product int his platform?
dina.ihab Thu, 07/09/2009 - 01:00
yes, i did it before. and it was dl380 too & also CCM 6.1 too.
antonio.vazquez Thu, 07/09/2009 - 02:04
Have you verify that if your part number, it is approved by Cisco to install this software. Although you have purchased a DL380G5, there is several part numbers associated to this model where it could change the processor speed, how much memory is installed,...
I have the same problem with a DL320 and I cannot install an IPIVR because processor speed was diferent that the processor speed that was approved by Cisco for this model.
Regards.
If you find this post useful, please rate it.
dina.ihab Thu, 07/09/2009 - 06:42
hi,
This the Part Number of the server :
458585-421
is this model supported by cisco to install the Call Manager 6.1 ?
and how can i know that and be certain through a document from Cisco ?
dina.ihab Thu, 07/09/2009 - 07:03
the part number stated in the previous is not the right one.
the right one is stated in the first message which is : 458565-421
regards
Ahmed Elnagar Sun, 07/12/2009 - 03:13
Hello;
I can see that in the document there are P/N for CM software that includes DL380 "CM6.1-K9-380G5"...Does this mean that these servers require special version of CM software other than the version for MCS??
antonio.vazquez Sun, 07/12/2009 - 22:47
no there is a equivalent between MCS and HP server. The software is the same because both servers are the same (MCS with Cisco Logo & HP with HP Logo)
Antonio
If you found this post useful, please rate it.
