ACE stopped passing traffic
stevejcutts
Hi I'm very new to the ACE module and need some ideas on a problem we had a few days ago. We have an ACE in a 6506 that stopped passing Internet Traffic for a period of time. It was reloaded twice but only after the second reload did it bust into life. A 'sh conn' showed that only a couple of connections were estblished over the ACE and also Health Checking was failing.
Any suggestions ?
sachinga.hcl
Level 4
Level 4
Hi Steve,
As you can see there is a caevet for this:
CSCsj30888-A reload of a non-ACE module in a Catalyst 6500 series switch may cause the ACE to stop passing traffic. Workaround: None.
SO can you please share that which version of software you are using on your ACE module.
sachin garg
Hi sachin,
Many thanks for the reply,
This is the ACE software version:-
Software
loader: Version 12.2[121]
system: Version A2(1.5) [build 3.0(0)A2(1.5) adbuild_00:30:35-2009/05/13_/a
uto/adbu-rel4/rel_a2_1_5_throttle/REL_3_0_0_A2_1_5]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_1_5.bin
installed license: no feature license is installed
