LMS : Config Collection “Partional Successful” message
Jul 9th, 2009
Dear All
Szenario:We have 2 CW Server one CWLMS2.6 and one CWLMS3.1 based on Solaris.
For CM3.1 I have the following problem:
If I make a Config Collection for a specific device or the entiry network I get a lot of “Partional Successful” Status messages. A lot of this messages are “VLAN RUNNING Config fetch failed for ….. Cause: VLAN Config is not supported using TFTP”
The startup and runnig Config is collected without problems.
The Transport Setting on both systems are Telnet, ssh, tftp.
CW2.6 has no failure during the config fetch.
What is wrong?
yjdabear Thu, 07/09/2009 - 06:10
  • Gold, 750 points or more
dkuhlen-goebel Wed, 08/05/2009 - 02:36
We tested all required ports, but the results are fine - all ports are open. (Of course the behavior doesn't change.) Do you have an other suggestion?
Thanks for your help.
