Fax on CUCM 7.x
Jul 9th, 2009
Hi All,
I'm still a beginner in the CCM World, hence turning to the experts.
I wanted to know whats the usual way to implement Fax solution in an IPT environment and how to configure the same (any links would be of great help)
Is it with the help of ATA or FXS card, and in any case is it Pass Through or Fax Relay or it could be used either way
I tried to locate any document however didnt find any, so I will be greatly honored by the help on this.
Kind Regards
Wilson Samuel
Overall Rating: 4 (1 ratings)
Wilson Samuel Tue, 07/28/2009 - 09:40
Guilherme,
Thank you so much for the information.
Also, I wanted to know how to setup to recieve the Fax in Inbox in Outlook for incoming faxes.
STEFAN CHRISTEN Wed, 07/29/2009 - 08:45
Hi Samuel
You can use T.37 On-Ramp Fax on your Cisco Voice Gateway to receive the Fax messages and forward them to a mail server. The On-Ramp Fax requires a TCL script on the Voice Gateway that can be downloaded from CCO.
You can find documentation and configuration instructions in the following documents:
http://www.cisco.com/en/US/docs/ios/voice/fax/configuration/guide/vf_t37_str-fwd_fax_ps6441_TSD_Products_Configuration_Guide_Chapter.html
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/voicemail/fxgatewy.html
Stefan
