frustrations with boson software
Jul 9th, 2009
  • Gold, 750 points or more
It seems that the quality & accuracy of the boson practice tests is not what it used to be
here is an example:
Incorrect. Your answer was: A
The correct answer(s): D
After the following configuration:
Router bgp 6500
Neighbor 10.1.1.1 remote-as 65000
What is the relationship to host 10.1.1.1?
A.) EBGP neighbor
B.) Confederation Peer
C.) Route Reflector Client
D.) IBGP neighbor
After the configuration of:
Router bgp 6500
The relationship to host 10.1.1.1 is Interior Border Gateway Protocol (BGP) neighbor.
This relationship would be an Exterior Border Gateway Protocol neighbor if the routers were in different
autonomous systems.
There are no Route Reflector Client or Confederation parameters in the configuration.
Cisco Press Book Reference: PDF Page - 447
Basic BGP Configuration Commands
QID: 65 Cisco Press CCNP BSCI
since the defined AS is 6500 wouldn't the remote AS of 65000 be an eBGP neighbor?
when does 6500 = 65000 ?
I would really like to hear others; impressions on good alternatives to the boson practice exams.
Eric
Overall Rating: 3 (1 ratings)
dwmcneil1 Thu, 07/09/2009 - 09:57
To be completely honest, I have yet to encounter a practice exam without a typo which rendered a question invalid, confusing, or downright frustrating...
The crux of the matter is knowing the material such that you are confident in your answers, and getting over the human mistake involved in creating the material... Again: Knowing the exam material is More Important. :)
As another example, every Sybex manual(and the included exams) I have ever read contained multiple typos/mistakes... Though they were mostly good reads :)
I will say that The Cisco Press books have been Very solid thus far (CCNA ICND1 & ICND2 -- Thank you Wendell Odom!!! CCNP-BSCI and BCMSN)
Peace,
Dan
Collin Clark Thu, 07/09/2009 - 12:57
  • Purple, 4500 points or more
The Transcenders are still pretty good. I used them when I had to re-cert.
Yes it would be an iBGP connection.
ericgarnel Fri, 07/10/2009 - 04:45
thanks for the feedback.
I still do not see how it would be iBGP as the AS #s are different
tperrier Sat, 07/11/2009 - 23:32
  • Silver, 250 points or more
Probably a typo (missing a zero).
ericgarnel Sun, 07/12/2009 - 10:53
That is my point entirely! There are too many typos & inaccuracies in the boson software
