IP SLA Fail back question
ngthen
If my ISP were to go offline and the route that I am tracking is removed, is there a way to set a time before it can return to the main line? I know I could simply pull the cable if the line goes down but I am wondering if there is a way to automate it. For example ISP 1 goes down and ISP 2 takes over. Can I say that ISP 1 must be back up for 1 hour before switching back?
5 Replies 5
johnspaulding
Yes,
After you create you IP SLA instance you create you track rtr's
under the following
track 1 rtr 1
delay down (seconds) up (seconds)
this should be the value you are looking for.
xcz504d1114
Level 4
Level 4
What method are you using to track? And are you running any routing protocols? BGP can suppress a route for a specified time period if it goes down then back up.
With object tracking, I believe the maximum abmount of delay you can introduce is 180 seconds.
HTH,
Craig
I am not using any routing protocols and I am using icmp-echo for tracking. I have 2 ISPs and one is pretty much just on standby unless the main goes down. For example
ip sla 1
icmp-echo 4.2.2.2
frequency 3
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 1
ip route 0.0.0.0 0.0.0.0 1.1.1.2 20
So I guess the question is with this config, is there a way to prevent the main from coming back online for a period of time?
The other poster had the right answer for you:
delay down
But it only has a limit of 180 seconds.
HTH,
Craig
Yes,
as previously posted
Taking your example
ip sla 1
icmp-echo 4.2.2.2
frequency 3
As mentions only up to 180 seconds
