ES+ 40 card (7606)
Answered Question
Jul 9th, 2009
1 port on the ES 40 card has both LED on.
documentation says:
Green and Amber On: Undefined condition.
what is that mean, good, bad ? don't use
thanks
Correct Answer by Jerry Ye about 7 years 8 months ago
Hi Atif,
Have you tried to swap SFP to 2/1? Change it and run the diag again. If problem presist, I think you might have an HW issue.
jerry
Overall Rating: 4.5 (2 ratings)
Jerry Ye Thu, 07/09/2009 - 07:28
  • Cisco Employee,
Hi Atif,
What is your version of IOS are you running? Can you post the output of show version and show module.
jerry
Atif Siddiqui Thu, 07/09/2009 - 07:31
only 1 port out of 40 is showing this message:
here it is.
PE4#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICES-M), Version 12.2(33)SRD1, RELEASE SOFTWARE (fc4)
PE4#sh module
Mod Ports Card Type Model Serial No.
2 40 7600 ES+ 7600-ES+40G3CXL JAE1309493P
3 40 7600 ES+ 7600-ES+40G3CXL JAE1309493M
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE12024CGH
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE JAE1130RD6Z
Mod MAC addresses Hw Fw Sw Status
2 0024.f94c.0bc0 to 0024.f94c.0c1f 1.0 12.2(33r)SRD 12.2(33)SRD1 Ok
3 0024.f94c.0fd0 to 0024.f94c.102f 1.0 12.2(33r)SRD 12.2(33)SRD1 Ok
5 001b.d401.6e40 to 001b.d401.6e43 5.2 12.2(33r)SRB 12.2(33)SRD1 Ok
6 0007.0e61.d8c0 to 0007.0e61.d8c3 5.2 12.2(33r)SRB 12.2(33)SRD1 Ok
Mod Sub-Module Model Serial Hw Status
2 7600 ES+ DFC XL 7600-ES+3CXL JAE13094A08 1.0 Ok
2 7600 ES+ 40xGE SFP 7600-ES+40G JAE1309487B 1.0 Ok
3 7600 ES+ DFC XL 7600-ES+3CXL JAE13062AG2 1.0 Ok
3 7600 ES+ 40xGE SFP 7600-ES+40G JAE13094881 1.0 Ok
5 Policy Feature Card 3 7600-PFC3C JAE12035PJY 1.1 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE12035FCF 1.1 Ok
6 Policy Feature Card 3 7600-PFC3C JAE1130RWR3 1.1 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1130RR38 1.1 Ok
Mod Online Diag Status
2 Pass
3 Pass
5 Pass
6 Pass
Atif Siddiqui Thu, 07/09/2009 - 08:03
I cannot access the ablve link.
I tried this, it gives error:
PE4#diagnostic mode enter module 2
Diagnostic mode is not supported in this image
Atif Siddiqui Thu, 07/09/2009 - 08:16
it gives me this message:
PE4#diagnostic start module 2 test 5 port 1
Diagnostic[Module 2]: Running test(s) 5 may disrupt normal system operation
Do you want to continue? [no]: yes
PE4#
*Jul 9 16:12:42.747: %DIAG-SP-6-TEST_RUNNING: Module 2: Running TestTransceiverIntegrity{ID=5} ...
PE4#
*Jul 9 16:12:42.747: %DIAG-SP-3-TEST_SKIPPED: Module 2: TestTransceiverIntegrity{ID=5} is skipped
on detail:
E4#show diagnostic result module 2 detail
Current bootup diagnostic level: minimal
Module 2: 7600 ES+ SerialNo : JAE1309493P
Overall Diagnostic Result for Module 2 : PASS
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
5) TestTransceiverIntegrity:
Port 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
. U U U U U U U U U . U U U U U U U U . U U U U
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
U U U U U U U U U U U U U U U U
Error code ------------------> 3 (DIAG_SKIPPED)
Total run count -------------> 0
Last test execution time ----> n/a
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> n/a
Total failure count ---------> 0
Consecutive failure count ---> 0
Correct Answer
Jerry Ye Thu, 07/09/2009 - 08:51
  • Cisco Employee,
Hi Atif,
jerry
