LMS 2.6 /RME 4.06 /Sol RICS0001:Internal Error
Jul 9th, 2009
I have met this error on a Solaris version of LMS.
I joined the file IC_server.log like it is mentionned under Troubleshooting faq.
What i would like to know is if it's the bug CSCsm97530 ?
What i saw with the bugtool kit it 's that the version 4.0.6 and version 4.2 are concerned too by this . So , does it means that any upgrade couldn't correct this bug and the patch has been applied step by step ..........?
Joe Clarke Thu, 07/09/2009 - 10:28
What devices are you having a problem with? What type of devices are they, and what versions of code are they running?
richard.tetu Fri, 07/10/2009 - 05:26
The equipements are cisco WS-C4506 Version 12.2(25)EWA5 and WS 6509 Version 12.2(33)SXH1 .Version 12.2(18)SXF8
I added the file which contains too, the hostnames of the switch and routers concerned.
Joe Clarke Fri, 07/10/2009 - 09:32
IC_Server.log only lists IP addresses. What are the IP addresses of these devices.
richard.tetu Wed, 07/15/2009 - 00:51
Hello Joe,
We ve got , by example , the device whith these ip adresse:
It seems that there is an error message associated on the IC_server.log
