night bell with CUCM 6.x
Jul 9th, 2009
My customer is requesting a night bell service for after hours calls. I know this is possible with CME, but they are running CUCM 6.x. Is there a 3rd party product that can accomplish this?
thanks all.
Jaime Valencia Thu, 07/09/2009 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    2011
You can try to do something similar with TOD so the calls go to X extension after hours
java
if this helps, please rate
jones2sr Fri, 07/10/2009 - 05:51
Thanks for the reply.
The customer is looking for a type of ring/bell to ring over the PA system that is currently running to a E&M card on the ISR router. Basically I'm thinking of some type of call park that makes the night bell ring and someone dials the DN for that call park.
