dstolt Thu, 07/09/2009 - 10:01
At an internal hidden data store that is not accessible by end users. If you want to save it as a file, you can use the the command "show checkpoint detail checkpointname > disk0: filename". That will allow you to see it or copy it off the system if you want.
Hope that helps,
Dan
sachinga.hcl Fri, 07/10/2009 - 01:18
HI,,
To display checkpoint information, use the show checkpoint command in Exec mode. The syntax of this command is:
show checkpoint {all | detail name}
The options and arguments are:
•all-Displays a list of all existing checkpoints
•detail name-Displays the running configuration of the specified checkpoint
For example, to display the running configuration for a specific checkpoint, enter:
host1/Admin# show checkpoint detail MYCHECKPOINT
Sachin
