ntp server
Jul 9th, 2009
We have the proper NTP server IP programmed on the gateway and on the Publisher. The phones are still showing a 3 minute difference with the Publisher. Any suggestions
htluo Thu, 07/09/2009 - 11:28
Follow steps below:
1) On the CUCM publisher command line, type "utils ntp status". Copy/paste screen output here.
2) Check the phone and see which CUCM server it registered with. Go to that CUCM server command line and type "utils ntp status". Copy/paste screen output here.
3) Compare the system time on step 1 and step 2. Are they in-sync?
Michael
http://htluo.blogspot.com
jalexan Thu, 07/09/2009 - 11:35
Hi Michael,
The phones are registering to the sub.
The Sub and Pub are Not in sync. The Sub is ahead by 3 minutes, same as the phones.
Jamie/kevin
htluo Thu, 07/09/2009 - 19:21
Subscribers' time should be in-sync with publisher.
If they are not synced, publisher might have problem. Could you go to PUBLISHER, type the command "utils ntp status" and paste the screen output here?
Thanks!
Michael
jalexan Fri, 07/10/2009 - 03:45
Hi Michael,
Here's a copy of the ntp status on the Publisher. I think the problem may be the publisher not syncronizing with the NTP server.
admin:utils ntp status
ntpd (pid 693) is running...
remote refid st t when poll reach delay offset jitter
127.127.1.0 LOCAL(0) 10 l 13 64 1 0.000 0.000 0.004
132.246.168.148 .INIT. 16 u - 64 0 0.000 0.000 4000.00
unsynchronised
time server re-starting
polling server every 64 s
Current time in UTC is : Fri Jul 10 11:38:42 UTC 2009
Current time in Canada/Atlantic is : Fri Jul 10 08:38:42 ADT 2009
htluo Fri, 07/10/2009 - 07:59
That's right.
If the publisher is not synced to NTP, subscriber won't sync to publisher.
You have two options:
Option 1: Fix the NTP sync issue on publisher.
Option 2: Disable NTP on publisher at all.
Either option would make the subscriber synchronize to publisher.
Michael
jalexan Fri, 07/10/2009 - 10:36
Thanks Michael..
If the Publisher's gateway is using an external NTP and is synced, the gateway should pass the ntp along if i have my gateway ip set as the ntp server in the PUB, correct?
Jamie
htluo Sat, 07/11/2009 - 10:22
NTP has to be explicitly configured on CUCM. There's nothing like "automatically".
Michael
