ACE SNMP vservers
Answered Question
Jul 9th, 2009
Anyone know if one can obtain # connections to a particular vserver via SNMP. I've got the vserver connections but I can't seem to find any SNMP information about rservers.
Correct Answer by Syed Iftekhar Ahmed about 7 years 10 months ago
Sachin
I am afraid you didnt understand the question :)
Anyways
Rserver connections:
cesServerFarmRserverTable (CISCO-ENHANCED-SLB-MIB)
VIP Connections:
slbVServerInfoTable (CISCO-SLB-MIB)
Syed
Overall Rating: 5 (1 ratings)
sachinga.hcl Fri, 07/10/2009 - 01:11
  • Silver, 250 points or more
Hi Osiris,
create custom probe(or scripted probe)like:
"type" = "custom-snmp"
"package" = "com.viacom"
"probe_name" = "snmp.ace"
"human_name" = "Cisco ACE Module"
"version" = "2.0"
"address_type" = "IP,AT"
"port_number" = "161"
display_name = "Miscellaneous/ACE Module Probe"
-- none
\GB\Prototype SNMP Probe\P\
This probe will monitor The Cisco ACE Module CPU, memory and global conection parameters
-- Parameters are user-settable values that the probe uses for its comparisons.
"Parameter1" = "1" -- Description of Parameter1
"Parameter2" = "2" -- Description of Parameter2
-- SNMP values to be retrieved from the device, and
-- Specify the variable name, its OID, a format (usually DEFAULT) and a short
description.
-- CALCULATION variables are computed from other values already retrieved from
the device.
entPhysicalSoftwareRev, 1.3.6.1.2.1.47.1.1.1.1.10.1, INTEGER,
"software version"
cpmCPUTotal1minRev, 1.3.6.1.4.1.9.9.109.1.1.1.1.7.1,
INTEGER, "CPU 1 minute"
cpmCPUTotal5minRev, 1.3.6.1.4.1.9.9.109.1.1.1.1.8.1,
INTEGER, "CPU 5 minute"
cpmProcExtMemAllocatedRev, 1.3.6.1.4.1.9.9.109.1.2.3.1.1.1.1,INTEGER,
"available memory"
cefcModuleUpTime, 1.3.6.1.4.1.9.9.117.1.2.1.1.8.1,
INTEGER, "ACE uptime"
slbStatsCreatedConnections, 1.3.6.1.4.1.9.9.161.1.1.1.1.6.9,
per-minute, "TCP and UDP CreatedConnections"
slbStatsEstablishedConnections, 1.3.6.1.4.1.9.9.161.1.1.1.1.8.9,
per-minute, "TCP EstablishedConnections"
slbStatsDestroyedConnections, 1.3.6.1.4.1.9.9.161.1.1.1.1.10.9,
per-minute, "TCP and UDP DestroyedConnections"
slbStatsReassignedConnections, 1.3.6.1.4.1.9.9.161.1.1.1.1.12.9, per-minute,
"TCP and UDP ReassignedConnections"
cslbxStatsCurrConnections, 1.3.6.1.4.1.9.9.254.1.1.1.1.3.9,
per-minute, "The number of connections currently still open."
cslbxStatsFailedConns, 1.3.6.1.4.1.9.9.254.1.1.1.1.5.9,
per-minute, "The number of connections balanced to real servers that then
failed to respond."
cslbxStatsHttpRedirectConns, 1.3.6.1.4.1.9.9.254.1.1.1.1.12.9,
per-minute, "connections made to HTTP redirect servers."
cslbxStatsDroppedRedirectConns, 1.3.6.1.4.1.9.9.254.1.1.1.1.13.9,
per-minute, "connections dropped by HTTP redirect servers."
-- The the text that will be appended
-- to the device's Staus Window.
\4\ entPhysicalSoftwareRev:\0\ ${entPhysicalSoftwareRev}
\4\ CPU Total 1min:\0\ ${cpmCPUTotal1minRev}
\4\ CPU Total 5min:\0\ ${cpmCPUTotal5minRev}
\4\ alloc free mem:\0\ ${cpmProcExtMemAllocatedRev}
\4\ ACE ModuleUp Time:\0\ ${cefcModuleUpTime}
\4\ Created Connections:\0\ ${slbStatsCreatedConnections}
\4\ Established Connections:\0\ ${slbStatsEstablishedConnections}
\4\ Destroyed Connections:\0\ ${slbStatsDestroyedConnections}
\4\ Reassigned Connections:\0\ ${slbStatsReassignedConnections}
\4\ Curr Connections:\0\ ${cslbxStatsCurrConnections}
\4\ Failed Conns:\0\ ${cslbxStatsFailedConns}
\4\ Http RedirectConns:\0\ ${cslbxStatsHttpRedirectConns}
\4\ Dropped RedirectConns:\0\ ${cslbxStatsDroppedRedirectConns}
Cheers!!
Sachin
sachinga.hcl Fri, 07/10/2009 - 18:42
Page 1 of 4
HI ,
Before you can run a probe script, you must copy the script onto the ACE, configure a script probe, and then associate the script with the probe.
1. Copy the script into the disk0: directory on the ACE. For example, to copy a script from an FTP server to the ACE and rename it to ACETCL, enter:
host1/Admin# copy ftp://192.168.1.1/test1/ECHO_PROBE_SCRIPT
disk0:ACETCL
Enter username:
At the prompt, you must provide a username for the server.
Note The filename that you assign the script must be unique across the contexts. You will use this filename when you load the script into the ACE memory and configure the probe.
2. If you are operating in multiple contexts, observe the CLI prompt to verify that you are operating in the desired context. If necessary, change to, or directly log in to, the correct context.
host1/Admin# changeto C1
host1/C1#
3. Enter configuration mode.
host1/Admin# config
Enter configuration commands, one per line. End with CNTL/Z
host1/Admin(config)#
4. Load the script into the ACE memory.
host1/Admin(config)# script file 22 ACETCL
5. Create a scripted probe.
host1/Admin(config)# probe scripted test1
host1/Admin(config-probe-scripted)# interval 10
host1/Admin(config-probe-scripted)# script ACETCL
host1/Admin(config-probe-scripted)# exit
6. Create a real server and a server farm. Associate the probe and real server to the server farm.
host1/Admin(config)# rserver host test
host1/Admin(config-rfarm)# ip address 10.1.0.105
host1/Admin(config-rfarm)# inservice
host1/Admin(config-rfarm)# exit
host1/Admin(config)# serverfarm host tests
host1/Admin(config-sfarm-host)# probe test1
host1/Admin(config-sfarm-host)# rserver test
host1/Admin(config-sfarm-host-rs)# inservice
host1/Admin(config-sfarm-host-rs)# Ctrl-z
At this point, the script probe should be running.
7. Use the show probe detail command in Exec mode to ensure that the script is running
8. Stop the script probe.
host1/Admin# config
host1/Admin(config-sfarm-host)# no probe test1
host1/Admin(config-sfarm-host)# exit
Contd.....
sachinga.hcl Fri, 07/10/2009 - 18:43
page 2 of 4
You load scripts onto the ACE through script files. A script file contains only one script. The ACE supports supports the configuration of 256 unique script files.
When using scripts on the ACE, the following considerations apply:
•Each script is always identified by its unique name as defined when copying the script file into the ACE disk0: file system. The script name must be unique across contexts.
•During probe configuration, you can assign a script to a probe. If the script is unavailable at that time, the probe attempts to execute the script and returns an error code. If this situation occurs, a syslog message displays to indicate the probe failure and why the probe failed. If the script is unavailable due to an error when loading the script, a syslog message would indicate the script load failure. You can also use the show script command to display the exit codes.
Copying Scripts to the ACE
You can copy a script from a server to the ACE disk0: file system by using the copy command in Exec mode. You can also copy the file from the supervisor engine to the ACE.
Because of virtualization, by default, a script file is copied into the directory for context that you are currently accessing. A script file in one context cannot be seen from another context. For details about virtualization, see the Cisco 4700 Series Application Control Engine Appliance Virtualization Configuration Guide. The syntax of this command is as follows:
copy [ftp://server/path | tftp://server[:port]/path | sftp://[username@]server/path] disk0:filename
The keywords and arguments are as follows:
•ftp://server/path-Specifies the File Transfer Protocol (FTP) network server and the source location of the script file including its filename.
•tftp: //server[:port]/path]-Specifies the Trivial File Transfer Protocol (TFTP) network server and the source location of the script file including its filename.
•sftp:[//[username@]server][/path]-Specifies the Secure Trivial File Transfer Protocol (SFTP) network server and the source location of the script file including its filename.
•disk0:filename-Specifies the destination filename for the script on the ACE disk0: file system. If you do not enter a filename, you are prompted to enter a filename or accept the source filename. You will use this filename when you load the script into the ACE memory and configure the probe.
Note The filename that you assign to the script must be unique across the contexts.
For example, to copy a script from an FTP server to the ACE, enter:
host1/Admin# copy ftp://192.168.1.1/test1/FTP_PROBE_SCRIPT
disk0:ftp1.tcl
Enter username:
You can also copy the zipped sample scripts file for the ACE onto disk0:. After you copy the zipped file, use the gunzip command in Exec mode to unzip its contents.
Contd.....
sachinga.hcl Fri, 07/10/2009 - 18:44
Page 3 of 4
Troubleshooting an SNMP Probe Issue
In this scenario, you have configured an SNMP probe, but the Last disconnect err field indicates that the sum of the weights does not add up to the maximum weight value as displayed in the output of the show probe detail command.
1. Display the probe status details by entering the following command:
ACE_module5/test# show probe detail
probe : SNMP_PROBE
type : SNMP
state : ACTIVE
description : snmp probe
port : 161 address : 0.0.0.0 addr type : -
interval : 15 pass intvl : 10 pass count : 3
fail count: 3 recv timeout: 10
version : 2c community : test_comm
oid string #1 : .1.3.6.1.2.1.4.3.0
type : ABSOLUTE max value : 1000000000
weight : 10000 threshold : 1000000000
------------------ probe results ------------------
associations ip-address port porttype probes failed passed health
serverfarm : least-loaded, predictor least-loaded
real : SERVER1[0]
192.168.10.45 161 -- 0 0 0 INIT
Socket state : CLOSED
No. Passed states : 0 No. Failed states : 0
No. Probes skipped : 0 Last status code : 0
No. Out of Sockets : 0 No. Internal error: 30
Last disconnect err : Sum of weights don't add up to max weight value <------- Error condition
Last probe time : Never
Last fail time : Never
Last active time : Never
Server load : 16000 <------- Note the server load value
The reason for this error is that the weight command needs to be configured when you have multiple OIDs configured for a single probe and from those OIDs if you want to give priority to a specific OID.
The sum of the weights should equal 16000 (see the Server Load field). For a single OID, the weight command does not have any significance.
2. Display the probe configuration by entering the following command:
ACE_module5/Admin# show runnig-config probe
probe snmp SNMP_PROBE
description snmp probe
port 161
interval 15
passdetect interval 10
version 2c
community TEST_COMM
oid .1.3.6.1.2.1.4.3.0
type absolute max 1000000000
weight 10000 <-------
In the above configuration, the weight is configured as 10000 for a single OID. The ACE is expecting another OID to be configured in the probe and the sum of both weights should equal 16000.
The configuration is not complete and the ACE is expecting additional parameters in the probe configuration. Because there is not another OID in the configuration, the ACE is not able to calculate the load and that is why the "Sum of weights don't add up to max weight value" error message appears.
Contd......
sachinga.hcl Fri, 07/10/2009 - 18:45
Page 4 of 4
3. Resolve the issue by modifying the probe configuration as follows:
description test
port 161
interval 15
passdetect interval 60
version 2c
community test_comm
weight 10000
oid .1.3.6.1.2.1.4.10.0
weight 6000 <------- 10000 + 6000 = 16000
4. Display the probe status details again by entering the following command:
ACE_module5/test# show probe SNMP_PROBE detail
probe : snmp1
type : SNMP
state : ACTIVE
oid string #2 : .1.3.6.1.2.1.4.10.0
weight : 6000 threshold : 1000000000
real : SERVER1[0]
192.168.10.45 161 -- 4143 0 4143 SUCCESS
No. Passed states : 1 No. Failed states : 0
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : - <------- No error indicated now. The probe is successful.
Last probe time : Mon Apr 6 09:12:54 2009
Last active time : Sun Apr 5 15:57:28 2009
Server load : 0
Using the Last Status Code Field
Details regarding the last status code field can be provided for nontrivial probes. For example, in the case of scripted probe PROBENOTICE_PROBE, the status code 30001 means that the probe is successful and the value 30002 indicates an error in probe arguments. The last disconnect error for status code 30002 displays "Did not receive correct response from the server," but the actual issue is related to arguments in the probe configuration, which can be checked by looking at the script for the probe.
ACE_module5/Admin# show probe TEST detail
probe : TEST
type : SCRIPTED
state : ACTIVE
description :
port : 0 address : 0.0.0.0 addr type : -
interval : 15 pass intvl : 20 pass count : 3
script filename : PROBENOTICE_PROBE
--------------------- probe results --------------------
probe association probed-address probes failed passed health
serverfarm : sf1
real : rs2[0]
23.0.0.5 4082 54 4028 SUCCESS
Socket state : RESET
No. Passed states : 6 No. Failed states : 5
No. Probes skipped : 8 Last status code : 30001 <------- Indicates success
Last probe time : Wed Apr 8 04:44:41 2009
Last fail time : Tue Apr 7 12:02:10 2009
Last active time : Tue Apr 7 12:03:45 2009
-----The end -----
Sachin Garg
sachinga.hcl Fri, 07/10/2009 - 18:50
Kindly find below a sample non-scripted probe for SNMP and UDP added to serverfarm as follows:
------START----
access-list ACL1 line 10 extended permit ip any any
probe udp UDP
interval 5
description THIS PROBE IS INTENDED FOR LOAD BALANCING DNS TRAFFIC
port 53
send-data UDP_TEST
description test
port 161
interval 15
version 2c
community test_comm
weight 10000
rserver host SERVER1
ip address 192.168.10.45
inservice
rserver host SERVER2
ip address 192.168.10.46
inservice
rserver host SERVER3
ip address 192.168.10.47
inservice
serverfarm host SFARM1
probe UDP
probe SNMP_PROBE
rserver SERVER1
inservice
rserver SERVER2
inservice
rserver SERVER3
inservice
class-map match-all L4UDP-VIP_114:UDP_CLASS
2 match virtual-address 192.168.120.114 udp eq 53
policy-map type loadbalance first-match L7PLBSF_UDP_POLICY
class class-default
serverfarm SFARM1
policy-map multi-match L4SH-Gold-VIPs_POLICY
class L4UDP-VIP_114:UDP_CLASS
loadbalance vip inservice
loadbalance policy L7PLBSF_UDP_POLICY
loadbalance vip icmp-reply
nat dynamic 1 vlan 120
connection advanced-options 1SECOND-IDLE
interface vlan 120
description Upstream VLAN_120 - Clients and VIPs
ip address 192.168.120.1 255.255.255.0
fragment chain 20
fragment min-mtu 68
access-group input ACL1
nat-pool 1 192.168.120.70 192.168.120.70 netmask 255.255.255.0 pat
service-policy input L4SH-Gold-VIPs_POLICY
no shutdown
ip route 10.1.0.0 255.255.255.0 192.168.120.254
-------END-------
Sachin Garg
sachinga.hcl Fri, 07/10/2009 - 18:57
Kindly find below a prototype for configuring a SNMP probe from Scratch:
"package" = "com.dartware"
"probe_name" = "snmp.prototype"
"human_name" = "Prototype SNMP probe"
"version" = "1.0"
display_name = "Miscellaneous/Prototype SNMP Probe"
-- none required
This is a prototype SNMP probe for InterMapper. It doesn't do anything as is, but can be used as the basis for a new probe.
This section contains text that will be displayed to the customer in the probe configuration window.
Describe the probe as much as necessary so that people will understand what it does and how it works.
-- Specify the default values here. The customer can change them and they will be retained for each device.
"Parameter3" = "3" -- Description of Parameter3
-- Specify the variable name, its OID, a format (usually DEFAULT) and a short description.
-- CALCULATION variables are computed from other values already retrieved from the device.
sysDescr, 1.3.6.1.2.1.1.1.0 , DEFAULT, "System's Description"
myOID, 1.3.6.1.2.1.1.3.0 , INTEGER, "Legend text if this were charted"
myOIDCalc, (($myOID-32)*5/9 ), CALCULATION, "A calculated value"
-- Specify rules for setting the device into Alarm or Warning state
alarm: $myOID < $Parameter1 "Condition string if this expression is true"
warning: $myOID < $Parameter2 "Condition string if this is true"
-- The section specifies the text that will be appended
\B5\Prototype SNMP Probe\0P\ \U2=http://${deviceaddress}\Go to the device's web page\P0\
\4\ Parameter1:\0\ $Parameter1
\4\ Parameter2:\0\ $Parameter2
\4\ Parameter3:\0\ $Parameter3
\4\ myOID:\0\ $myOID \3G\GHz\mp0\
\4\ myOIDCalc:\0\ $myOIDCalc \3\minutes (\0\$sysUptime \3\ hundredths of seconds)\p\
Sachin Garg
sachinga.hcl Fri, 07/10/2009 - 19:03
Example Custom SNMP Probe Page 1 of 2
-- WARNING: This probe is provided as an example, of a custom probe. It is a tutorial
-- and therefore is wordier than your real probe needs to be.
-- You should use the "Prototype Custom SNMP Probe" as the basis for all new probe work.
-- It's simpler, and you won't have to "rip anything out" as you begin.
"probe_name" = "snmp.example"
"human_name" = "Example SNMP probe"
"version" = "1.0"
display_name = "Miscellaneous/Example SNMP Probe"
-- none required; see the Developer Guide for the values that go here.
-- The contains text that will be displayed in the probe configuration window.
-- Describe the probe as much as necessary so that people will understand what it does and how it works.
\GB\Example SNMP Probe\P\
This probe is an example of an InterMapper Custom SNMP probe, and many of the features that are described in the Custom Probes section of the \u2=http://www.intermapper.com/docs/developer/index.html\Developer Guide\P0\. If you have questions about this probe, \u2=mailto:[email protected]\please contact us.\p0\
This probe probably isn't really useful for production work. However, it provides an example of various techniques available in custom SNMP probes.
It retrieves a few SNMP values from a device by specifying their OIDs and how to display those values in the device's Status Window.
The probe also has thresholds for setting the device into alarm or warning.
In this example, the device has will go into alarm or warning if it has been rebooted recently (controlled by the \i\RebootAlarm\p\ and \i\RebootWarn\p\ parameters - two and three minutes, by default) or if there aren't as many interfaces as expected in the ifTable (controlled by the \i\ExpectedInterfaces\p\ parameter.)
The parameters are:
\b\RebootAlarm\p\ Put the device into alarm if the sysUptime is less than this many minutes.
\b\RebootWarn\p\ Put the device into warning if the sysUptime is less than this many minutes.
\b\ExpectedInterfaces\p\ Put the device into warning if the the ifNumber is greater or equal to this value.
\b\InterfaceToMonitor\p\ is the ifIndex of the interface to monitor for traffic.
\b\TrafficWarn\p\ and
\b\TrafficAlarm\p\ are thresholds for traffic alarms on the named interface.
In addition, this probe shows:
- CALCULATION variables, the conversion from centi-seconds (hundredths of a second) to seconds
- Formatting of the Status Window, in the section
- Marking up text in the \i\description\p\ and \i\snmp-device-display\p\ sections using IMML (InterMapper Markup Language) to get bold, italic, colored text, etc.
- IMML also allows you to create a link to a URL, using the \\U2=http://xxxx\\ notation shown in the \i\snmp-device-display\p\ section.
"RebootAlarm" = "2" -- 2 min = 120 seconds = 12,000 centi-seconds
"RebootWarn" = "3" -- 3 min = 180 seconds = 18,000 centi-seconds
"ExpectedInterfaces" = "3" -- expected number of interfaces
"InterfaceToMonitor" = "1" -- Interface to monitor for traffic
"TrafficWarn" = "200" -- traffic to get a warning
"TrafficAlarm" = "1000" -- traffic to get an alarm
Contd.....
sachinga.hcl Fri, 07/10/2009 - 19:04
Example Custom SNMP Probe Page 2 of 2
sysUptime, 1.3.6.1.2.1.1.3.0 , INTEGER, "Uptime - in centi-seconds"
sysContact, 1.3.6.1.2.1.1.4.0 , DEFAULT, "Name of person to contact"
sysName, 1.3.6.1.2.1.1.5.0 , DEFAULT, "Name assigned to system"
sysLocation, 1.3.6.1.2.1.1.6.0 , DEFAULT, "Location of the system"
ifNumber, 1.3.6.1.2.1.2.1.0 , DEFAULT, "Num. of rows in the ifTable"
ifInOctets1, 1.3.6.1.2.1.2.2.1.10.$InterfaceToMonitor,PER-SECOND, "Number of received octets on interface 1"
sysUptimeMinutes, ($sysUpTime / (100 * 60)), CALCULATION, "Uptime in minutes"
alarm: $ifInOctets1 > $TrafficAlarm "Traffic above the alarm threshold"
alarm: $sysUptimeMinutes < $RebootAlarm "Rebooted less than $RebootAlarm minutes ago"
warning: $ifInOctets1 > $TrafficWarn "Traffic above the warning threshold"
warning: $sysUptimeMinutes < $RebootWarn "Rebooted less than $RebootAlarm minutes ago"
warning: $ifNumber != $ExpectedInterfaces "Not as many interfaces as expected"
\4\ sysDescr:\0\ $sysDescr
\4\ sysContact:\0\ $sysContact
\4\ sysName:\0\ $sysName
\4\ sysLocation:\0\ $sysLocation
\4\ sysUpTime:\0\ $sysUptimeMinutes \3\minutes (\0\$sysUptime \3\ hundredths of seconds)\p\
\4\Num. of Intf:\0\ $ifNumber \3\(expected $ExpectedInterfaces)\0\
\4\Input traffic:\0\ $ifInOctets1 \3\(bytes/second)\0\
-----End of page 2.......
Sachn garg
Correct Answer
Syed Iftekhar Ahmed Mon, 07/13/2009 - 17:13
  • Blue, 1500 points or more
Sachin
Anyways
VIP Connections:
Syed
osiristrading Thu, 07/16/2009 - 09:53
Thanks Syed, that's what I was looking for.
Sachin, thanks for the useful information nonetheless - will come in handy no doubt.
