Identify call-forward extension
Jul 9th, 2009
Is there a quick way in CUCM6.1.2 to identify all the extensions that are using CFA and what number they are fwd'ing to?
We have a situation where one extension gets fax tone from a call and the CLID is the mask we assign to all phones. So short of looking at each extension to see what the CFA settings are configured for I was hoping there is a quick way to do this. I tried by using SQL from PUB cmd line and using CDR application but no luck.
Thanks.
Jaime Valencia Thu, 07/09/2009 - 12:00
  • Cisco Employee,
  • Hall of Fame,
    2011
only thru qrys on numplan table via cli, there is no reporting for what you want
java
if this helps, please rate
