Best method to connect two SR520s through VPN
Jul 9th, 2009
What do people recommend in terms of connecting two SR520s through VPN?  I am trying to connect a small business and a home office together.  I tried to configure it through CCA 2.0, but am stuck with a Down-Negotiating problem.  Any push in the right direction would be appreciated.
Edit:
For instance, should I not even try to use CCA for this?  Does anyone have experience connecting two of these routers in a site to site configuration?  It seems that documentation is quite sparse on the subject.  Any clarification would be helpful.
addis Fri, 07/10/2009 - 06:06
This is supported in CCA. The best way is to configure the office SR500 as EZ-VPN server, home SR500 as EZ-VPN client.
davidsarel Fri, 07/10/2009 - 06:38
That's what I figured, and I've been doing that but have been having some issues.  I upgraded to the newest CCA (2.0(1)), and I'm going to reset the routers to factory defaults and try again.  I'll post back with my results.  Thanks for responding.
Related Content
