murabi Thu, 07/16/2009 - 07:44
This should work. Since we are using two HWIC cards (two wan interfaces), its is equivalent to two point to point links to the same destination. So this can either be used for backup/ redundancy or increasing the total throughput.
pjmcdougall Thu, 07/16/2009 - 23:47
Thks for your reply. Yes my thoughts also. Given the limited bandwidth of 3G you'd think there would be mention of this technique by Cisco. Might have to give it a try.
Roman Rodichev Sat, 07/25/2009 - 20:55
  • Gold, 750 points or more
Keep in mind that if both 3G cards connect to the same carrier, you are not doubling the bandwidth. If you want to double bandwidth, you will need to use two different carriers.
Roman
pjmcdougall Sun, 07/26/2009 - 01:05
Thanks Roman, but if I use a different framed-route (attrib 22) with each connection the carrier has no idea that the two connections come from the same physical device. Then I just use IOS smarts to route the traffic.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
