Can 2821 Gigabit Ethernet ports support Layer 3 routing?
Answered Question
Jul 9th, 2009
Hi, can the 2 build in gigabit ethernet ports support layer 3 routing? I have a Metro-E connection that needs to terminate in this router. Can this be done or do I have to get the HWIC-1FE card to support this?
Correct Answer by Joseph W. Doherty about 7 years 9 months ago
As also noted by Leo, yes you can route on the two built in Ethernet ports. If you need more than two gig ports, another can be added using the HWIC-1GE-SFP. You also have the option of adding two HWIC-1FEs, one HWIC-2FE, or one of the Ethernet switch modules. (The latter routes via VLANs).
Something to keep in mind, a 2821 doesn't really have sufficient processing performance to guarantee routing at 100 Mbps let alone gig, although 10 Mbps should be fine.
Correct Answer by Leo Laohoo about 7 years 9 months ago
How will the connection from your Metro-E be presented to the 2821?
The 2821 has 2 routed Gig ports.
Overall Rating: 3 (2 ratings)
Correct Answer
Leo Laohoo Thu, 07/09/2009 - 21:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Correct Answer
Joseph W. Doherty Fri, 07/10/2009 - 03:27
