How to block calls in UC?
Jul 9th, 2009
How can i block calls using UC? Block 24x7. Example, need to block the following sample cellphones.
0102207714
0182504678
0182612150
Please provide configuration assistant.
Best regards,
Lawrence Chew
David Harper Thu, 07/09/2009 - 21:38
In CCA, navigate to Configure > Telephony > Dialplan > Outgoing, and in the outgoing call handling tab, add a new pattern for each number and set the permission to Blocked.  That's all there is to it.
Cheers,
Dave.
wfchew2007 Fri, 07/10/2009 - 01:58
Can you also provide them in command lines, instead of via CCA ? My CCA seem not working, prefer to use CLI instead.
Best regards,
Lawrence Chew
wfchew2007 Fri, 07/10/2009 - 08:28
Seem like what i want, but i am to block outgoing calls. Maybe just replace the 'incoming' to 'outgoing'. Can this be done?
Best regards,
Lawrence Chew
