LMS- RME 4.2
Answered Question
Jul 9th, 2009
I cannot reload a switch using netconfig job, i get the following error message: Message: Couldnot enter ENABLE Mode from USER Mode on Device. Primary Login Succeeded
/ Secondary Enable Succeeded
Is there something i can do to correct this? the user accounts are managed by ACS, and it not a problem with other devices.
Correct Answer by Joe Clarke about 7 years 7 months ago
Yes. Netshow will use the same credentials.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 07/09/2009 - 21:48
It looks like there is a problem with your enable credentials in DCR for this device. Verify that they are correct. If you are using telnet, it would be a good idea to get a sniffer trace of the Netconfig job to confirm the credentials RME is using.
lucky.sibanyoni Thu, 07/09/2009 - 22:00
I use the same credentials to telnet to the device and its working fine, and for other devices as well-but this device is managed by a different ACS server, can a problem be on ACS or is it on DCR? how can i do a sniffer trace of the Netconfig job?
Joe Clarke Thu, 07/09/2009 - 22:12
There appears to be some credential mismatch. You can start a packet capture from Device Center. Filter on all telnet traffic to this device, then start your Netconfig job.
lucky.sibanyoni Thu, 07/09/2009 - 22:44
HI
Thanks, it loks like its working.
i did a device credentials check on Device center; and it failed, i then edit the device credentials- and i found that: i had a username, password and also enable password- i therefore removed the enable password- and did a device credentails check on telnet and Telnet Enable Mode User Name and Password. and its working.
this should also work on the netshow jobs (like using the show command jobs?)
lucky.sibanyoni Thu, 07/09/2009 - 23:01
can i ask one last question?
is it possible to pull out a report in LMS for EAP? i.e we have interfaces that are configured with eap, and some r not configured- i'd like to pull out a report for all the interfaces that have eap configured and also those that dont have eap configured:
i.e. below is the output of sh run int g1/3, and this interface has eap configured- so i'd like to pull out a report for the switch, dat will show me if an interface has eap or not
test#sh run int g1/3
Building configuration...
Current configuration : 590 bytes
interface GigabitEthernet1/3
switchport
switchport access vlan 23
switchport mode access
wrr-queue bandwidth 30 70
wrr-queue queue-limit 40 30
wrr-queue random-detect min-threshold 1 40 80
wrr-queue random-detect min-threshold 2 70 80
wrr-queue random-detect max-threshold 1 80 100
wrr-queue random-detect max-threshold 2 80 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 2 3 4
wrr-queue cos-map 2 2 6 7
mls qos trust dscp
dot1x pae authenticator
dot1x port-control auto
spanning-tree portfast
service-policy input SOFTPHONE-PC
end
