location of vlan.dat
Jul 9th, 2009
Normally we get the vlan.dat file in flash but i am unable to find the same file in sup720. I need this file to delete the complete vlan information. Please do let me know the exact location of the file
jimmysands73_2 Thu, 07/09/2009 - 21:44
  • Silver, 250 points or more
It depends what vtp mode your switch is in if it even has a vlan.dat and if so, where it is located.
I believe vlan.dat is used by VTP server and trans mode while VTP client only saves it in its running-config. Its late, I could be wrong.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/configuration/guide/swvtp.html#wp1205076
milan.kulik Thu, 07/09/2009 - 23:46
  • Red, 2250 points or more
try "dir all-filesystems" command.
I can see
Directory of const_nvram:/
1 -rw- 1596 vlan.dat
on Cat 6500 equipped with SUP720-3B.
BR,
Milan
