MAC ADDRESS ERROR
Answered Question
I am getting following error when i configure isis on XR device.How to fix please help
RP/0/5/CPU0:133#RP/0/5/CPU0:Jul 9 21:46:06.759 : ifmgr[198]: %PKT_INFRA-LINK-3-UPDOWN : Interface MgmtEth0/5/CPU0/1, changed state to Up
RP/0/5/CPU0:Jul 9 21:46:06.762 : ifmgr[198]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface MgmtEth0/5/CPU0/1, changed state to Up
RP/0/5/CPU0:Jul 9 21:46:06.828 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
RP/0/5/CPU0:Jul 9 21:47:08.770 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
RP/0/5/CPU0:Jul 9 21:48:08.806 : netio[294]: %ROUTING-CLNS-3-ETHERENCAP : Incorrect MAC address length 0
Correct Answer by Giuseppe Larosa about 7 years 11 months ago
Hello Pramod,
post the router isis config
it looks like it is not able to correctly encapsulate the IS-IS PDU on an ethernet frame.
To be noted also that if you are trying to run IS-IS on a management interface this can be part of the problem you shouldn't use it to route user traffic but only for management
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 07/10/2009 - 03:21
  • Hall of Fame,
    Founding Member
Hello Pramod,
Hope to help
Giuseppe
