debug signalisation process
Jul 9th, 2009
Hello group,
Question: I have an IP network with serveral locations. One location has a special problem. There are 7960 and 7970 IP Phones in use.
When I call to this location, the phone signals but it takes approximately 3 to 5 seconds for a call connect!!!! A call transfer is nearly impossible.
The network access is clean and with 4Mbit high enough. Trace and ping to the CUCM are OK.
No other location has this problem.
My question: How / Which debug can I use to find the problem ?
thx a lot
Patricio
Overall Rating: 5 (1 ratings)
Nicholas Matthews Mon, 07/13/2009 - 10:37
  • Red, 2250 points or more
Hi Patricio,
You can do a few things, but so far we have no idea what your call flow is.
Here are debugs for different situations:
FXO/FXS/T1 cas:
debug vpm signal
PRI:
debug isdn q931
H323:
debug h225 asn1
debug h245 asn1
SIP:
debug ccsip message
MGCP:
debug mgcp packet
SCCP:
debug sccp messages
You'll also want:
debug voip ccapi
Turn on this global command:
service timestamp debug datetime msec local
That will help you find out where the delay is in your network.
On your voice gateway, also use:
show voice dsp detail
Make sure that you don't have a message that says ! Non-default firmware is in use
or make sure your flash does not have: guido.dsp, hdv2.dsp, or dsp_c5510.rbf in your flash.
-nick
