bgp next-hop-unchanged command
Jul 9th, 2009
cisco (AS 200)---> L3switch (AS 100)---> GW router (AS 100)
i am configuring ebgp peer between GW router (AS100) to cisco (AS 200). in My L3 switch ospf is running and i had created static route to cisco AS 200 ip block and i had redistributed into ospf
in my GW router while configuring ebgp neighbor if i configure below command what will be the impact
neighbor x.x.x.x next-hop-unchanged
adahiya Fri, 07/10/2009 - 00:37
BGP next-hop-unchanged command is used to send BGP updates to BGP peers without modifying the next hop attribute. In your scenerio I don't think its required
